what is the part number for 93 type S pistons?
prelude type s was only avalible in japan as a 5th gen model only. Why dont you try and get 4th gen JDM pistons. I belive they came with 10.6:1 compression. Im not sure if this is due to head/block design or from piston design. but its worth a shot. Im pretty sure type s piston will fit into the h22a1 block, but dont quote me on this.
interesting, the jdm pistons might be a better option for me compared to the type s because my head is milled 43 thou of an inch.
Is a comperssion lever of 11-4-1 to high? or should I play it safe and run 11-1??
the type s prelude wasn't around till 1997.And,yes,They will fit your block.I have those pistons in a 91 h22a block!Its best to get the .25mm overbore and have the block honed to size.Dam,and besides,with a 43 thou mill,might as well just get the jdm 10.6 compression pistons..
[Modified by aeolus, 8:18 AM 5/9/2002]
[Modified by aeolus, 8:20 AM 5/9/2002]
Bimmerman
Jun 9, 2006 05:52 AM
