2001 Accord - Bad Tensioner or Balance Shaft
Old Oct 31, 2006 | 10:07 PM
Obd 1uan's Avatar
Default 2001 Accord - Bad Tensioner or Balance Shaft
I have a 4 cylinder 2001 accord ex, and I just installed my new timing belt/water pump/tensioners/tensioner belt/seals etc. Well as i finished the car everything sounds great, i then drive the car everything sounds great. Well i try driving the car again about 30 minutes later and i start to get major vibration in the cabin. So i know the balance shaft is off somehow. I take the car apart, the timing belt is still at tdc, and my front balance shaft is still aligned with mark on the block but the rear shaft is now off by 1 or 2 teeth. I dont see how this happen because the balance shaft belt was still tight, and i checked all the teeth on the rear balance shaft and they are all there. So i dont see how only the rear shaft moved ?????
Old Nov 1, 2006 | 05:35 PM
Ross 2.0's Avatar
In a Junkyard near you.
A 2001 accord does not have balancer shafts.
Can you explain your question a little better?
Old Nov 1, 2006 | 10:02 PM
JimBlake's Avatar
Default Re: (Ross 4107)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ross 4107 &raquo;</TD></TR><TR><TD CLASS="quote">A 2001 accord does not have balancer shafts...</TD></TR></TABLE>Huh?
Is his F23 that much different than my '98 F23?
Old Nov 2, 2006 | 05:47 PM
Honda-Master's Avatar
Can you explain your question a little better?</TD></TR></TABLE>
2003 is when they changed the set up ..
if the belt was tight it would be real hard that it jumped any teeth ....
you did not install the little bolt ( 10mm head ) in the t- belt tensioner by any chance did you ??
colostatedj
Mar 24, 2014 08:24 PM
anahiem714
Aug 11, 2008 04:50 AM
3arnetts
Apr 15, 2008 06:39 PM
aenema
Jul 26, 2004 04:24 PM
92hybridAccord
Apr 19, 2004 10:36 AM
