jacksonSC on a type r
do you think a jackson supercharger. on a jdm itr motor can handle 10 psi of boost? im not sure if i should try it. because i have one off my gsr and going turbo. and figure might as well put it on the type r. i personally think thats to much boost for a stock R. i will definantly have to get a tune in it. let me know what you guys think and what i should do.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Madspeed »</TD></TR><TR><TD CLASS="quote">GSR intake manifold bolt pattern is different from the ITR....the SC won't bolt up.</TD></TR></TABLE>
i had the same exact thing in mind. unless you wanted to swap heads i dont see it happening
you are 100% right, will not work
well guys i do have the other manifold because i had it on a type r and only ran stock boost 6psi. so it wont be a problem just have to change the gaskets from blower to manifold
Cynical 1
Jun 29, 2010 03:35 PM
infulleffect
Jun 10, 2004 08:48 AM
