Remove Power steering
Old Oct 31, 2006 | 04:34 PM
Drifte's Avatar
Default Remove Power steering
A friend of mine is going turbo, was wondering what most do to rid a 97ex of power steering? Some people remove everything and just add a loop of hose on the rack. Do most guys run an older model rack?
any suggestion greatly appreciated.
Old Oct 31, 2006 | 05:02 PM
Drifte's Avatar
Default Re: Remove Power steering (Drifte)
also was wondering if a non vtec head would be a better choice. theirs one for sale in our area, and I have heard vtec and turbos dont get along
Old Oct 31, 2006 | 05:10 PM
stock_honda_coupe's Avatar
Don't know about the power steering, but Vtec runs a higher compression ratio and thus making it harder to get the boost right.
Old Oct 31, 2006 | 05:13 PM
Drifte's Avatar
running a built block, just wondering about the head though. can i just stick the non vtec head in...or maybe leave the vtec head and unplug the relay etc.
Old Nov 1, 2006 | 05:33 PM
Default Re: (Drifte)
The non vtec head is optimal for boost in my opinon. unpluging the vtec on the vtec head won't bring the compression ratios down. I would suggest asking around and seeing what success other people have had with different set ups.
Old Nov 1, 2006 | 07:01 PM
williejohnson's Avatar
New User
have 2 civics right now cx with manual steering and si with power
call me a whatever but i like the power
i would say if it has it leave it if not o well
Old Nov 1, 2006 | 08:30 PM
nello a.'s Avatar
search. i know there is a thread aboout getting rid of power steering.
44 results from search. archived "removing power steering"
Old Nov 1, 2006 | 10:33 PM
98vtec's Avatar
moderator emeritus
Default Re: (nello a.)
your rack configuration should be the same as my ludes......
https://honda-tech.com/zerothre...86242
i looped my hoses at the rack.
Old Nov 2, 2006 | 07:29 AM
RyanEJ8's Avatar
Default Re: (stock_honda_coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stock_honda_coupe &raquo;</TD></TR><TR><TD CLASS="quote">The non vtec head is optimal for boost in my opinon. unpluging the vtec on the vtec head won't bring the compression ratios down. I would suggest asking around and seeing what success other people have had with different set ups.</TD></TR></TABLE>
Not true. The compression is fine for boost. I run 10:1 C/R for boost.
Old Nov 2, 2006 | 07:49 AM
Kruzen510's Avatar
Default Re: (RyanEJ8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RyanEJ8 &raquo;</TD></TR><TR><TD CLASS="quote">
Not true. The compression is fine for boost. I run 10:1 C/R for boost.</TD></TR></TABLE>
agreed, 10.6:1 here with 12psi.
BOOSTEd2
Oct 7, 2009 08:10 AM
sonson6
Dec 11, 2007 09:56 AM
