Code 43 Fuel supply help
Old Oct 31, 2006 | 03:19 PM
wheelmaneg6's Avatar
Default Code 43 Fuel supply help
My car wont start. It will not start, before it cut off i got a code 43 = Fuel supply then it sputtered and bogged really baddly. I have a new walbro 255hp fuel pump. I took off the fuel rail with the injectors connected and let them sit out on top of a cloth to see if they are sprayin. Only injector #4 is spraying and the others have barely anything coming out. I wired the resistor box exactly as specified, I have no idea what it could be
Old Oct 31, 2006 | 03:45 PM
JasonST's Avatar
Default Re: Code 43 Fuel supply help (wheelmaneg6)
Code 43 is usually the o2 sensor, but from the sounds of ur problem I'd say theres a good chance it's something with the fuel pump, make sure all the wiring is right,double check it, and hopefully the fuel pump isn't defective.
str8JDMteggy
Sep 29, 2006 08:27 AM
cincispeedemon
Nov 22, 2004 05:51 PM
importimage
Jun 30, 2003 04:27 PM
89 CRX SI
Apr 22, 2003 03:22 PM
