J30A1 in a 93 civic?
Old Oct 31, 2006 | 11:22 AM
fearfactory17's Avatar
Default J30A1 in a 93 civic?
i got a fresh J30A1 from the factory, never been fired once
how easy would this swap, with a 5 speed into my 93 civic be?
im new to honda, all i usually work on is gm
i know ill need a new ecm, harness, custom motor mounts, and the pedals and everything for the manual swap
ive heard the J30A1 has some problems with the cam, is there better heads i can bolt on?
will my fuel pump be able to give enough pressure or will i need a new one of those too
like i said im new to honda so any input would be appreciated,
how good are these engines handling boost?
Old Oct 31, 2006 | 11:30 AM
dohcVTECeg2's Avatar
Default Re: J30A1 in a 93 civic? (fearfactory17)
wtf is a j30a1?
Old Oct 31, 2006 | 11:32 AM
dem0nk1d's Avatar
here is a j30 swap into a 88-91 civic hatchback. same ideas apply not major custom fab work... but it's going to be a little fab and cash...
https://honda-tech.com/zerothread?id=1741656
fventura03's Avatar
Default Re: J30A1 in a 93 civic? (dohcVTECeg2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dohcVTECeg2 &raquo;</TD></TR><TR><TD CLASS="quote">wtf is a j30a1?</TD></TR></TABLE>
1998 - 2002 Honda Accord 3.0 V6 2dr (Engine: J30A1)
Old Oct 31, 2006 | 11:58 AM
prjctwhteg's Avatar
Default Re: J30A1 in a 93 civic? (fventura03)
nice motor choice how much did that run you being brand new?
Old Oct 31, 2006 | 12:42 PM
williejohnson's Avatar
New User
Default Re: J30A1 in a 93 civic? (prjctwhteg)
OMG always wanted to see one in a 92-95 good luck
Old Oct 31, 2006 | 12:46 PM
platinumx6's Avatar
How much did that run ya, and what is the specs/weight on this motor and its tuning ability. Sum1 tell me im searchin with **** for results..
Old Nov 1, 2006 | 11:08 AM
i got the engine very cheap off a friend i know with amazing hookups, not sure on the weight but i know it pushes around 200 hp/165 pounds of torque stock.
its just the short block, i need heads and a manifold,
thats why i was asking how good the heads are on this engine, i heard somethig about the valves not opening fully
is there a better set of heads i can slap on this thing?
and id love to know how this engine is at handlind boost, but from what ive seen, it doesnt seem many are familiar with it
Old Nov 2, 2006 | 03:27 PM
Old Nov 2, 2006 | 06:00 PM
Skunk.Werks's Avatar
its frankly way to ******* big
Old Nov 2, 2006 | 06:03 PM
na+b18c_hatch's Avatar
interesting. i've thought about a V6 in a hatch, but never really considered it myself. whatever floats your boat i guess. it would definitely be pretty rare, at least around here (md/va/dc/pa)
Old Nov 8, 2006 | 05:41 PM
lil vin's Avatar
Default Re: (dem0nk1d)
thats crazy
Old Nov 8, 2006 | 05:44 PM
Kruzen510's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fearfactory17 &raquo;</TD></TR><TR><TD CLASS="quote">i got a fresh J30A1 from the factory, never been fired once
</TD></TR></TABLE>you'll probably want new suspension up front to support the extra weight if you go through with it.
Old Nov 8, 2006 | 06:12 PM
black7hatch's Avatar
Default Re: J30A1 in a 93 civic? (Kruzen510)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lil vin &raquo;</TD></TR><TR><TD CLASS="quote">thats crazy</TD></TR></TABLE>
haha i agree. if it fits do it tho
Old Nov 8, 2006 | 07:39 PM
95lscivic's Avatar
Default Re: J30A1 in a 93 civic? (black7hatch)
frankly its probably not a good idea, unless you really know what you're getting into. j30s are funny motors also in that they have the exhaust manifolds built into the heads making exhaust flow a difficult thing. they're decent motors in that they're high displacement(for a honda) and that they are torquey but its honestly not really worth it, especially when you can build a 300whp b series for three grand give or take. just think about your options. yes it would be pretty cool, but practical? probably not.
Old Nov 8, 2006 | 07:53 PM
wrinkles's Avatar
ive heard that the head from a CL type S, has an increase in flow of around 50 cfm over the stock J30 heads, and i believe that is the J32 engine that they come from. correct me if im wrong.
Old Nov 8, 2006 | 08:18 PM
Sleepy_Red_hatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kruzen510 &raquo;</TD></TR><TR><TD CLASS="quote">you'll probably want new suspension up front to support the extra weight if you go through with it.</TD></TR></TABLE>
custom spring rates FTW
Old Nov 8, 2006 | 10:14 PM
props_honda85's Avatar
Default Re: J30A1 in a 93 civic? (Sleepy_Red_hatch)
another good idea would be to go the accord section and track down a little bit more information on this motor, your prolly only gonna get so much info out of us here in the civic forum...but good luck on the swap also good luck with the fab work, your gonna have your work cut out for you... go at it
Old Nov 8, 2006 | 10:19 PM
spork motorsports's Avatar
* B A N N E D *
Default Re: (K Stef)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95lscivic &raquo;</TD></TR><TR><TD CLASS="quote">frankly its probably not a good idea, unless you really know what you're getting into. j30s are funny motors also in that they have the exhaust manifolds built into the heads making exhaust flow a difficult thing. they're decent motors in that they're high displacement(for a honda) and that they are torquey but its honestly not really worth it, especially when you can build a 300whp b series for three grand give or take. just think about your options. yes it would be pretty cool, but practical? probably not.</TD></TR></TABLE>
dude the exhaust sstme in those heads are perfect for a.....................twin turbo setup!!!!! 2 adapeter plates and 1 pieace of pipe per head dude holy ****, you got yourself a fwd supra! impossible to control and rediculous horespower(compared to other front wheel drive cars)
honda supra FTW!!!!
Old Nov 9, 2006 | 01:13 AM
broketuner-Sol_Si's Avatar
Default Re: (spork motorsports)
HAVE'NT SEEN IT DONE TOO MANY TIMES, BUT ALL THE TIMES i'VE SEEN IT DONE IT'S HAD AN AUTO TRANNY
SOUNDS LIKE YOU'RE ON THE RIGHT TRACK
TYPE S FROM A CL 3.2 LITER MOTOR
NEW ONE WOULD BE SMART
SEEN QUITE A FEW SCd BUT ONLY A FEW TWIN TURBO'D SETUPS, ALL PUSHING AROUND 300WHP SO FAR HAVEN'T HEARD OF ANY BLOWING UP...YET
-I've seen it done twice into EGs and now that EF. IMO they aren't worth the extra weight, unless you were to twin turbo(like someone else already said) it and make it a drag only car.
-If you're serious about putting that into an EG, better really be competent in wiring or have deep pockets to pay someone who is. Not to mention the fab work.
-also consider, it's got MUCH LESS aftermarket support than most B, D, F, H or K series motors.
-I think it'd be cool just to say you've got a V6 under the hood, but for the cost factor, I think your money could be better spent elsewhere.
Hoser
Jan 12, 2015 11:12 AM
civicsib16b
Aug 13, 2005 08:49 AM
chulopilong
Aug 14, 2003 04:59 AM
