needheLpasapO2 Simulater
Old Oct 31, 2006 | 08:42 AM
bbhockey19's Avatar
Default needheLpasapO2 Simulater
I have a99civicex and iPut in a Hi-flow cat and i remoVed O2 sensor do they make an O2simuLator so I can wire itto the cut o2 wiRes so the check engine light is off so i can pass NY inpection
Old Oct 31, 2006 | 09:05 AM
Rodney's Avatar
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
Default Re: needheLpasapO2 Simulater (bbhockey19)
why not just put an o2 bung in the cat?
Old Oct 31, 2006 | 09:55 AM
F20Cteg's Avatar
Yes, O2 simulators are made, but I would put the O2 sensor in there since they will most likely check that the sensor is physically after the cat. Also if it is anything like cali, they won't pass you with a "high-flow" cat.
Good luck.
Old Oct 31, 2006 | 10:23 AM
bbhockey19's Avatar
Default Re: needheLpasapO2 Simulater (F20Cteg)
what is an o2 bung
Old Oct 31, 2006 | 10:47 AM
IT'S ME DAVID's Avatar
NooB
look at the pix on this thread.02 bung is where the 02 sensor plugs into.
http://hondamarketplace.com/zerothread?id=1713573
Old Oct 31, 2006 | 11:56 AM
JSPECSIR's Avatar
Default Re: needheLpasapO2 Simulater (IT'S ME DAVID)
yeah put the o2 back in. if your hi flo means resonator and not really a cat. then put the o2 back in and wire a 1 megohm resistor in line with the o2 signal wire. that will keep the ecu thinking the cat is working.
Old Oct 31, 2006 | 04:03 PM
bbhockey19's Avatar
Default Re: needheLpasapO2 Simulater (JSPECSIR)
is there steps on doing this....
pizzamanprelude
Aug 2, 2006 03:26 PM
smkngsr
Apr 6, 2005 01:58 PM
spoon23_JDizM AkA SpOoN20
Dec 12, 2004 08:26 PM
R-1303
Jun 24, 2002 07:00 PM
