88 Accord LX (manual 4dr pwr everything) DOOR PANEL REMOVAL
Old Oct 30, 2006 | 06:35 PM
ishbog's Avatar
Default 88 Accord LX (manual 4dr pwr everything) DOOR PANEL REMOVAL
I've googled, searched this site and others, but have found nothing on how to get the drivers inside door panel off, without busting the damn thing.
My outside driver door handle busted one side august 2nd, and i've been careful with it since then, and tonight, it finally gave. Now, I have to crawl in my passenger door to get in the driver's seat.
Tonight, I managed to get the whole side panel loose, unplug the controls and whatnot, but CANT get the thing to come all the way off, giving me access to the inside door handle. I'm visiting the junkyard tomorrow to scavenge one off another accord...
Does anyone have any diagrams or anything about the door panel removal? any help?
Thanks for reading, all.
Old Oct 31, 2006 | 04:09 AM
Ross 2.0's Avatar
In a Junkyard near you.
There are a lot of screws in there. be sure to look around and find them all. If your still having trouble by this evening i'll take some pictures of mine and show you how
Old Oct 31, 2006 | 05:31 AM
ishbog's Avatar
Default Re: (Ross 4107)
I was able to get a ridiculous amount of screws off, as well as the plastic tabs, but the top trim part wouldn't come free. does the window need to be down?
I'll let you know if i have any luck tonight.
Old Oct 31, 2006 | 06:31 AM
Ross 2.0's Avatar
you need to pick it up and unhook it from the top of the door
Old Oct 31, 2006 | 07:00 AM
ishbog's Avatar
I've put insane amounts of upward pressure, even with help from a friend, on the door panel, and it just wont pop off...
Old Oct 31, 2006 | 01:26 PM
ishbog's Avatar
Default Re: (ishbog)
heading to the junkyard now, hopefully i'll find an identical model (called beforehand, they said they had some...) and figure it out better that way...
results and pics tonight, might make a ******* article out of it.
and, for the record, jumping in the passenger door and over the set e-brake is actually kind of fun, and makes me feel like a ninja. or a douche.
Old Nov 1, 2006 | 07:11 AM
ishbog's Avatar
i got a new handle and side mirror (broke that too) at the junkyard. I managed to yank the panel off the car at the junkyard, but im not sure it was at a point where i could put it back on...
Whats the exact procedure for getting it all the way off, after screws?
also, does anyone have any guides to replacing the handle?
Old Nov 2, 2006 | 12:04 PM
OD's Avatar
OD
does the bottom of it flap around if you pull it? if not, put a flat head screw driver were its not, and pry it out, there are little clips holding it in which you just pry out, and can bang back in later. if youcan almost pull the door panel off, just the top part by the window is stopping you then get a flat head screw driver and pry the trim off, it would be easier with the window down too
Old Nov 2, 2006 | 12:36 PM
ishbog's Avatar
Default Re: (OD)
thanks for the help. I ended up figuring it out, and it WAS easier with the window down. Got the new handle in, though i now have a blue car with a gold handle... i have pics if you would like...
Old Nov 2, 2006 | 03:22 PM
Ross 2.0's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ishbog &raquo;</TD></TR><TR><TD CLASS="quote">thanks for the help. I ended up figuring it out, and it WAS easier with the window down. Got the new handle in, though i now have a blue car with a gold handle... i have pics if you would like...</TD></TR></TABLE>
Sorry I had assumed you rolled the window down. That was my fault.
but i'm glad you got it
Shadowsstrife
Apr 21, 2017 06:51 PM
Former User
Apr 23, 2013 10:48 AM
southeastbeast
Oct 25, 2007 11:19 AM
ryan ortego
Jul 31, 2005 09:17 PM
