09 Accord Sedan LX - removal and installation of front driver door skin
Fixing a dented front driver's door.
Part 4 in diagram here.
Does anyone know what is involved with removing and installing the door skin? Must spot welds be cut and remade? Or does it slide off? I don't see any bolts that secure it to the door panel.
Thanks
Thanks
My Name is Nobody
Re: 09 Accord Sedan LX - removal and installation of front driver door skin
I'm pretty sure that's a spot weld scenario. grind them off, and spot weld the new one on.
Maybe a Saturn had a true removable skin,
Seagull Management
I've never seen a door the skin wasn't welded to or attached with some sort of panel bond. Here's a pretty good guide with good pictures on how to replace a door skin for pretty much anything:
https://honda-tech.com/forums/paint-body-84/replace-door-skinz-3129662/
https://honda-tech.com/forums/showthread.php?t=3129662
Seagull Management
It really shouldn't be that bad Ron, zing around the seams with a 4 1/2" angle grinder and run a chisel under the panel to remove. I'd say the hardest part would be crimping the new panel on.
I think I get the grinding. That seems clear at the link.
What's the chisel part? To break the spot welds?
And then the crimping...so I assume the edges of the new skin must be precisely and evenly refolded...what tool is used for crimping?
And would the last step be spot welding?
Thanks.
Seagull Management
The chisel part is to finish separating the skin from the door, it may not actually be welded, it may just be crimped and attached with panel bonding adhesive.
There's a proper tool mentioned in the article I linked to, but failing that a body hammer and dolly will work I believe.
No welding, just panel bonding adhesive and seam sealer.
Shadowsstrife
04-21-2017 06:51 PM
