Koni yellow problem
Old Oct 30, 2006 | 06:17 PM
Punkaddic's Avatar
Default Koni yellow problem
I have a problem with one of my koni, the bushings on the rear shock is coming out. What should i do ?? Press it back in place or replace with a new one under warranty ? here's a pix
Old Oct 30, 2006 | 06:57 PM
Spoon*EK9's Avatar
if u press it back in, there's always a chance it will pop back out. besides, if it's covered under warranty you might as well get it done right.
Old Oct 30, 2006 | 07:27 PM
KayOs's Avatar
Default Re: Koni yellow problem (Punkaddic)
Use the warranty and get yourself a replacement Koni yellow.
Old Oct 31, 2006 | 01:05 PM
ITR184's Avatar
Did these come off the new ITR or the old one? If it's off the wrecked one did it pop out during impact? If so I would press it back in and see how tight it feels.
Old Oct 31, 2006 | 10:04 PM
christuffeR's Avatar
Default Re: Koni yellow problem (Cod Sac)
if its under warranty might as well get a new one if you try to push it back could pop out and cause more problems later
Old Nov 1, 2006 | 02:51 AM
Punkaddic's Avatar
its comin from the old one, anyway i send the pictures to the shop where i bought them to know if its covered by the warranty or not
Old Nov 1, 2006 | 02:57 AM
GAME OVER 2007's Avatar
Default Re: (Punkaddic)
koni yellows are lifetime warranty so take care of it
Old Nov 1, 2006 | 03:14 AM
ITR184's Avatar
since it is pinched between the LCA, it isn't going any where. Will the bushing spin in the housing? Even if does spin it probably will not have any play between the LCA once it's tightend. If you do get a new one, I would think about replacing the other side as well (depending on how much abuse it has seen).
Old Nov 1, 2006 | 08:12 AM
actionanh's Avatar
Default Re: (Cod Sac)
just get full coilovers! this won't happen GET ZEALS! lol
Gekko
Suspension & Brakes
Sep 29, 2010 08:54 AM
M-Spec
Oct 17, 2005 07:10 PM
gsr-mike
Jun 18, 2004 05:55 PM
01GSRcpe
Jun 2, 2003 10:51 AM
IN2VTEC
May 5, 2003 01:07 PM
