Tranny started grinding 2nd - > 3rd
Old Oct 30, 2006 | 04:46 PM
90gs's Avatar
Default Tranny started grinding 2nd - > 3rd
It used to only do it when I was in vtec, but lately its been getting sooner and sooner... now it does it at anything above about 4000rpm.
Its about time to change the tranny fluid anyways so are there any additives I (or the dealership) can put in to help with that?
Old Oct 30, 2006 | 06:07 PM
jdm_eg06's Avatar
Default Re: Tranny started grinding 2nd - > 3rd (90gs)
try using gm syncromesh fluid. hard to find these days buts its damn good stuff
Old Oct 30, 2006 | 06:23 PM
vlc92189's Avatar
yeah.. use syncromesh worked wonders for me, but its not hard to find... just go to a chevy dealership
Old Oct 30, 2006 | 06:33 PM
whatsthatnoise's Avatar
Default Re: (vlc92189)
replace 3rd gear gearset and synchro sleeve
Old Oct 30, 2006 | 07:17 PM
NaGsrHatch's Avatar
i used gm syncro mesh cured my 2nd 3rd still a little rough
Old Oct 30, 2006 | 08:58 PM
Honda Bull's Avatar
Default Re: Tranny started grinding 2nd - > 3rd (NaGsrHatch)
GM synchro mesh or Honda MTF won't fix that issue. You'll more than likely have to rip the tranny apart and replace the synchro's and sleeves. Atleast the 3rd gear one.
But try the change of tranny fluid first, and make sure the fluid is at the correct level. If this fails, well... start pulling the tranny out if you can't drive it like it is.
Old Nov 1, 2006 | 10:43 AM
90gs's Avatar
Default Re: Tranny started grinding 2nd - > 3rd (Honda Bull)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Honda Bull &raquo;</TD></TR><TR><TD CLASS="quote">GM synchro mesh or Honda MTF won't fix that issue. You'll more than likely have to rip the tranny apart and replace the synchro's and sleeves. Atleast the 3rd gear one.
But try the change of tranny fluid first, and make sure the fluid is at the correct level. If this fails, well... start pulling the tranny out if you can't drive it like it is.</TD></TR></TABLE>
i can drive it just fine, just bothers me that if i ever want to accelerate fast in 2nd gear i either have to go into 4th right after or grind the gears...
will the honda dealership put GM fluid in for me?
Old Nov 1, 2006 | 12:37 PM
Honda Bull's Avatar
Doubt it. They'll put in Honda MTF (Manual Transmission Fluid) in for you though. They do the same thing for the most part. Some people will say they work the same, some people say GM is better. I personally say they're basically the same.
Tranny fluid isn't too difficult to do though. You could probably do it yourself and put in the GM Synchromesh if you wanted to.
Rikaro
10
Jun 6, 2007 04:38 PM
ex_ricer
Mar 18, 2007 10:12 PM
1.8
23
Oct 3, 2004 03:32 PM
metal-x
Sep 13, 2002 09:47 AM
ill phil
15
Sep 4, 2002 10:37 PM
