I'm getting mis-fire codes, but car doesnt seem to be mis-firing?
Old Oct 30, 2006 | 04:45 PM
typeR#0427's Avatar
Default I'm getting mis-fire codes, but car doesnt seem to be mis-firing?
Hey Type-R people again. My Car seems to be un-happy again.
Recently removed VAFC-II
Adjusted Cams back to zero, intake and exhaust
Changed plugs to NGK iridium 9
now the car is getting random misfire codes on cylinder 2,3 and 4. and its getting the random multi misfire code too.
The car doesn't seem to be having any problems. Other than the CEL. What could possibly be causing this. i just wanted to get your thoughts before i tear into this engine, again
mileage:82k
new timing belt, water pump and headgasket at 66k
never money shifted, or anything like that. opinions welcome
Old Oct 30, 2006 | 07:59 PM
ITR#132's Avatar
Default Re: I'm getting mis-fire codes, but car doesnt seem to be mis-firing? (hamB18C5)
Check your timing and use different plugs. Make sure your spark plug wires are on tight.
Old Oct 30, 2006 | 08:26 PM
mtber's Avatar
Default Re: I'm getting mis-fire codes, but car doesnt seem to be mis-firing? (ITR#132)
What actual code are you throwing ?
Go to http://www.phearable.net/tech and review the MIL section.
Old Oct 30, 2006 | 09:09 PM
typeR#0427's Avatar
Default Re: I'm getting mis-fire codes, but car doesnt seem to be mis-firing? (mtber)
looks like 73-76.
the obd-II said p-301, p-302, p-304. if i remember correctly
Old Oct 30, 2006 | 09:57 PM
B2FiNiTY's Avatar
sounds like it has to do with the vafc being removed. Are all the wires put together correctly?
Old Oct 31, 2006 | 08:25 AM
typeR#0427's Avatar
Default Re: I'm getting mis-fire codes, but car doesnt seem to be mis-firing? (B2FiNiTY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY &raquo;</TD></TR><TR><TD CLASS="quote">sounds like it has to do with the vafc being removed. Are all the wires put together correctly? </TD></TR></TABLE>
yes sir. it actually felt better after i took out the VAFC. but i triple checked those wires, do you think a crossed wire would do this?
Old Oct 31, 2006 | 08:39 AM
00BaseRacer's Avatar
Got similar problems with my Prelude, all signs are pointing to dirty/stuck/broken EGR Valve. I had this problem a few months back with just over 100k mi. I ended up removing egr, filling port with "Seafoam", and running car at high idle. CELs went away till now, maybe 10k mi later. You might want to give the seafoam a try. You can find it at NAPA. But I think I am going to have to replace mine. Cheers, Wj
Old Oct 31, 2006 | 08:42 AM
typeR#0427's Avatar
Default Re: I'm getting mis-fire codes, but car doesnt seem to be mis-firing? (00BaseRacer)
nice. you ended up replacing the EGR? i have heard sea-foam is pretty sketchy, is that true?
GeorgeBurns
Honda Civic (2001 - 2005)
39
Sep 23, 2013 04:14 PM
cgoldman11
Jul 7, 2012 06:37 PM
Bigrome34
Jul 6, 2010 10:47 AM
2mansi
Dec 12, 2007 10:33 AM
typeR#0427
Nov 1, 2006 08:37 AM
