ITB on a Type R
Old Oct 30, 2006 | 01:01 PM
allmotorcrx2001's Avatar
Default ITB on a Type R
Any one know if ITB will work good on a Type R. Is there any bad to it??
Old Oct 30, 2006 | 01:03 PM
walker111's Avatar
Default Re: ITB on a Type R (allmotorcrx2001)
Of course and of course
Old Oct 30, 2006 | 01:23 PM
jdmspoonitr's Avatar
Default Re: ITB on a Type R (walker111)
what is it these days??
Old Oct 30, 2006 | 01:26 PM
Black R's Avatar
25 Year Member
.....check my thread(s) on the subject.
Old Oct 30, 2006 | 01:27 PM
totsie7944's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allmotorcrx2001 &raquo;</TD></TR><TR><TD CLASS="quote">Any one know if ITB will work good on a Type R. Is there any bad to it??</TD></TR></TABLE>
hehe just added some on my R....can't wait till Nov 18th get this biatch tuned up and rouring!
Old Oct 31, 2006 | 06:37 AM
P1_Variable's Avatar
Go play with your buddies in the CRX forum. Don't bring questions like this that you have obviously done no research on to the ITR forum. =P
Old Oct 31, 2006 | 08:03 AM
Default Re: (Black R)
Ok Black R so did you ever get the ITB's running on the car good?
Old Oct 31, 2006 | 08:11 AM
typer_696's Avatar
Default Re: (allmotorcrx2001)
You just need your car to be able to handle ITB's and some serious tuning. You will get impressive gains from ITB's
Old Oct 31, 2006 | 08:18 AM
LunchboxZT's Avatar
Default Re: (typer_696)
Upside = serious power (if tuned correctly) down side = if you don't have a box for them you run the risk of damaging engine internals because they're wide open.
Old Oct 31, 2006 | 08:28 AM
Default Re: (LunchboxZT)
Thanks for your positive feed back people, I am getting ready to pick up a set today and finish my build.
Old Oct 31, 2006 | 10:43 AM
92TypeR's Avatar
FSAE
You can make more power from a properly built and tuned plenum, and have less headaches from tempormental tuning, fabrication to run filters...etc
The ONLY benefit to ITB's is throttle response. And bling, if you're into that.
Old Oct 31, 2006 | 10:51 AM
THC07's Avatar
Default Re: (92TypeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92TypeR &raquo;</TD></TR><TR><TD CLASS="quote">You can make more power from a properly built and tuned plenum, and have less headaches from tempormental tuning, fabrication to run filters...etc
The ONLY benefit to ITB's is throttle response. And bling, if you're into that.</TD></TR></TABLE>
IAB+tune=gains
IAB wired into VTEC+ tune = Bigger gains, 3lbs tq
Old Oct 31, 2006 | 12:06 PM
Default Re: (THC1107)
Well based on the feed back it does not seem like something I should do. The guy also said that they need to synchronize so thats something I will have to do or get done so they can open all the way at the same time.
Old Oct 31, 2006 | 07:41 PM
THC07's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allmotorcrx2001 &raquo;</TD></TR><TR><TD CLASS="quote">Well based on the feed back it does not seem like something I should do. The guy also said that they need to synchronize so thats something I will have to do or get done so they can open all the way at the same time.</TD></TR></TABLE>
Synchronize vtec and IAB?????? how would you do that?
they get voltage/Vac and open.
Old Oct 31, 2006 | 09:46 PM
92TypeR's Avatar
FSAE
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by THC1107 &raquo;</TD></TR><TR><TD CLASS="quote">
IAB+tune=gains
IAB wired into VTEC+ tune = Bigger gains, 3lbs tq</TD></TR></TABLE>
Do you know what you are talking about?
First of all, ITR's don't even have an IAB (check the forum you are in), secondly, neither do ITB's.
Old Nov 1, 2006 | 06:34 AM
THC07's Avatar
i guess not. i figured that itb was iab. now im just lost
Old Nov 1, 2006 | 08:04 AM
No the seller told me I have to have them sync so they open and closed at the same time. The TWM has linkages underneath to adjust its not like the Toda
Old Nov 1, 2006 | 08:36 AM
92TypeR's Avatar
FSAE
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allmotorcrx2001 &raquo;</TD></TR><TR><TD CLASS="quote">No the seller told me I have to have them sync so they open and closed at the same time. The TWM has linkages underneath to adjust its not like the Toda </TD></TR></TABLE>
TWM's are garbage. They make sh*t for power and they have too many inherent problems that make them a PITA. You will make way more power with an IB intake manifold and 70mm tb than TWM's ever will.
Old Nov 1, 2006 | 11:41 AM
totsie7944's Avatar
TWM's are garbage. They make sh*t for power and they have too many inherent problems that make them a PITA. You will make way more power with an IB intake manifold and 70mm tb than TWM's ever will.</TD></TR></TABLE>
yea toda and jenvey are the brands to go with if your looking for ITBs
Old Nov 1, 2006 | 12:14 PM
Chris N's Avatar
IAB+tune=gains
what the crap?? : Passes out :
I think your username is affecting your brain activity.
(i do like the 1107 part for sentimental reasons, however)
Agreed.
And there is enough bling loving in here to make ITB's a serious topic.
That, and there actually are some informative threads about this topic, if the thread poster was so inclined to search.....
chris - who wonders what in the hell is going on in here lately.
Old Nov 1, 2006 | 05:31 PM
MK Ultra's Avatar
Any time you have multiple throttle plates, they need to be synchronized to open together. This is not a big deal, at least on an inline engine.
It was a bit of a pain synching the Dellorto carbs on my Karmann Ghia, because it was a boxer engine and there was a good 24" between the two carbs, making the linkage a bit cumbersome. But even then, it's one of those things you don't have to do very often.
Old Nov 2, 2006 | 05:41 AM
totsie7944's Avatar
Not trying to argue, but there have been some custom designed ITB's out there as well. Actually the Jenvey ITB's I bought the horns were custom built for a certain power band, and as of yet no manifold has made more power than them. The previous owner is a well respected tuner in and tested them against many manifolds.
Just a point that properly designed and tuned ITB's, along with the throttle response, could in fact be as good or better than a manifold.
JayBinNyC88
Honda Civic (2006 - 2015)
Jan 10, 2007 02:31 PM
miss type r tia
Jan 2, 2007 07:31 PM
VELOCITY R
Acura NSX
Apr 19, 2004 11:27 AM
TypeR15
Jan 29, 2004 06:50 AM
.ShawnD.
Aug 26, 2003 06:00 PM
