NEED HELP installing a OEM Speedometer into an EG Hatch
Old Oct 30, 2006 | 09:55 AM
JDMEG61988's Avatar
Default NEED HELP installing a OEM Speedometer into an EG Hatch
hey guys, i need help removing and installing an OEM cluster into my EG hatch. Any pointers, steps, or advice any one wants to give me please give me a shout.
Cheers,
Trevor
Old Oct 30, 2006 | 09:57 AM
TurboTagTeam's Avatar
Default Re: NEED HELP installing a OEM Speedometer into an EG Hatch (JDMEG61988)
https://honda-tech.com/zerothread?id=661308
This is pretty much everything you need to know...Good luck
Old Oct 30, 2006 | 10:01 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Welp, you will need to get the gauge bezel out without breaking it, which is your first challenge.
First, remove the hazard switch. You can usually get it if you have long fingernails or a knife or a pick. There is one phillips screw behind there.
Next, there are two other screws directly above the cluster. You can see them if you look up from the top of your steering column.
Now that all the screws are out, you are going to have to pry the top of the bezel out slightly, and pry the bottom of it out, and it should pop free.
Now you only have the four screws of the cluster itself. The new cluster is plug and play.
Enjoy.
Old Oct 30, 2006 | 10:15 AM
JDMEG61988's Avatar
Hey Guys,
Thanks for all the help ill let you all know how it went!
Cheers Guys
Trevor Gulyas
Old Oct 30, 2006 | 10:45 AM
WhiteOnRice's Avatar
Be careful when removing all those clips, they like to break. You need a lot of patience.
91efbluehatch
Dec 27, 2010 08:19 PM
JunkyardAccord
16
Mar 7, 2008 02:18 PM
EH-3
Nov 19, 2005 12:45 PM
karmannghia
Nov 7, 2001 06:16 AM
owen_the_soyboy
Sep 11, 2001 05:23 AM
