suspension setup need help
here the layout i'm going to be upgrading the suspension on my 90 civic sedan. this is the parts i'm going to be installing spw coilovers, spw upper strut bars, kyb agx shock/strut set, progress front camber kit, skunk2 rear camber with rear lower contol arms also this setup will be with 16" wheels with 205/40/16 tires. the car will be dropped to it reaches the tires almost. i just want to know if the setup will be strong and if the car and so jumpy. if anybody has any other ideas of a better setup please post
just get regular drop springs. take your pick.
if you insist on coilovers, get ground control. dont ask about what rates, jsut get whatever they offer.
forget about camber kits.
forget about LCA.
if you need to replace bushings, get OEM.
get an alignment when youre done to fix your toe.
forget about LCA.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson »</TD></TR><TR><TD CLASS="quote">just get regular drop springs. take your pick.
forget about LCA.
get an alignment when youre done to fix your toe.</TD></TR></TABLE>
Tyson knows his stuff. I agree with everything he says here, especially the part about getting the toe aligned after lowering.
forget about LCA.
