need help w/ tranny.
hello ive search and i also looked @ the "facts before posting". no anwers for me
like the title says,when i drove today the car was shaking,im just about to engage the clutch and the car just suddenly shakes,i added little gas then shaking stops. if i just use my friction zone the car shakes.if i apply a little gas it stops shaking. 3rd seems rough. its not like smooth like butter , its as if something is holding it from going in/ out smoothly? clutch was all the way in and going through some gears.Please Help?
thnx
edit: i test drove the car today,its still hard to get in gears. and when i got home. i decided to go trough each gears while the engine is running and clutch all the way in. i couldnt get it on any gear. wat could me the problem? please help. thnx in advance
Modified by 98itRspec at 1:28 AM 10/30/2006
Modified by 98itRspec at 11:52 AM 10/30/2006
Modified by 98itRspec at 12:43 AM 10/31/2006
thnx
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98itRspec »</TD></TR><TR><TD CLASS="quote">hello ive search and i also looked @ the "facts before posting". no anwers for me
thnx
edit" sorry for the horrible ******* English!!!
Modified by 98itRspec at 1:28 AM 10/30/2006</TD></TR></TABLE>
thnx
97 R 551xx miles. tranny is all stock. cant get in any gear.
pleasee help.
Modified by 98itRspec at 11:54 AM 10/30/2006
pleasee help.Modified by 98itRspec at 11:54 AM 10/30/2006
Maybe your clutch self-destructed. How hard are you on the clutch?
I remember for the first 47k miles I double clutched all the time. This caused the spring retainer to break on the clutch and pieces of the clutch broke apart. I could hardly get into any gear.
Sounds clutch related...only one way to find out
You can also disconnect the transmission linkage and manually shift the trans at the shift shaft with the car off of course and on sturdy jack stands. If you can manually shift it then you know what to look at next.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98itRspec »</TD></TR><TR><TD CLASS="quote">i called u yesterday but the lady @ ur work told me u werent there. wats a good time to call u? </TD></TR></TABLE>
I am in and out
Best thing is to leave a message and I will return your phone call.
clutch fluid is top off. how do u check tranny fluid? so should i replace my clutch? any recomendations. i was also planning on getting a lightweight flywheel. im also limited on funds
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98itRspec »</TD></TR><TR><TD CLASS="quote">clutch fluid is top off. how do u check tranny fluid? so should i replace my clutch? any recomendations. i was also planning on getting a lightweight flywheel. im also limited on funds
Try bleeding the line
Check all the easy and most obvious stuff first
If would suck for you to go through taking the transmission off and find out you just had a bad clutch slave cylinder.
</TD></TR></TABLE>Try bleeding the line
The clutch isn't disengaging all the way. Assuming the hydraulic system is operating correctly there are 3 possibilities:
Worn/weak spring seats on pressure plate
[replace PP]
Clutch disc dragging on PP/flywheel. (Warped/broken disc, broken spring seat)
[replace disc]
Broken, bent, or shot throw out bearing.
[replace throwout bearing]
Your car is likely shaking because the motor can't maintain proper idle speed.
Just get a new clutch/pp/to
[replace PP]
[replace disc]
took it to a transmission specialist today,had it diagnost. getting there is b*tc*. ill let u guys know when i hear from them. thnx for all the help.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sohc it to me »</TD></TR><TR><TD CLASS="quote">can you shift into gears with the car off, if you can its your clutch</TD></TR></TABLE>
yes i can. i dont even need to touch the clutch. thats wat the guys said @ the shop.
he said my disc plate/clucth plate etc. is worn off. 656 a fair price w/ oem clucth,instalation,fluid etc. wat do u guys think? thnx in advance
Modified by 98itRspec at 7:02 PM 11/2/2006
Modified by 98itRspec at 10:58 AM 11/3/2006
- Vici0us -
Transmission & Drivetrain
Sep 18, 2012 01:39 PM
