Suspension & Brakes Theory, alignment, spring rates....
------> you think i'll rub with my setup?
Old Oct 29, 2006 | 11:35 PM
Got Utensils's Avatar
Default ------> you think i'll rub with my setup?
okay, well im currently drop on neuspeed race springs on my teg. (2'' rear/2.25'' front). now i am looking to get some rims,16 x 7.0. do you think i'll encounter some rubbing? let me know thankssss.
Old Oct 30, 2006 | 06:44 PM
spock_rocker's Avatar
memoryFAB.com representative
Default Re: ------> you think i'll rub with my setup? (Got Utensils)
depends on the offset of the wheels!
Old Oct 30, 2006 | 07:37 PM
02 accord's Avatar
Default Re: ------> you think i'll rub with my setup? (spock_rocker)
And on the tires.
Old Oct 30, 2006 | 08:32 PM
Default Re: ------> you think i'll rub with my setup? (02 accord)
offset is +40, and tires 205/45/16.
Old Oct 30, 2006 | 08:55 PM
you might in the rear.. front you should be fine.
Old Oct 30, 2006 | 09:29 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spock_rocker &raquo;</TD></TR><TR><TD CLASS="quote">you might in the rear.. front you should be fine. </TD></TR></TABLE>
ah, i was thinkin i would be rubbin in the front and fine in the rear.
Old Oct 31, 2006 | 08:48 PM
TunerN00b's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Got Utensils &raquo;</TD></TR><TR><TD CLASS="quote">offset is +40, and tires 205/45/16. </TD></TR></TABLE>
Was running lowered to flushed tires with 205/45-16 on 16x7 wheels with a 42 offset on my teg, and the rear was not a problem at all. The fronts would rub going into and out of driveways due to suspension compression, but nothing worth worrying about.
That 2mm difference would help with the front rubbing, and I think I had 2mm to spare between the tire and the fender in the back, but nothing a rolled fender wouldn't cure.
Old Nov 1, 2006 | 03:26 AM
unimportant's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Got Utensils &raquo;</TD></TR><TR><TD CLASS="quote">ah, i was thinkin i would be rubbin in the front and fine in the rear.</TD></TR></TABLE>
That's what I was thinking,
I'm running the same wheel / tire setup on my EF, which isn't lowered.. The integra has a bit more room, but when you lower it 2" it will bring the tire up and in. I'm going to say you're going to get rub on the outside of the tire on the wheel well.
Old Nov 1, 2006 | 09:33 AM
dvp's Avatar
dvp
Default Re: ------> you think i'll rub with my setup? (unimportant)
You'll be fine. If there is going to be any rubbing it will only be on the inner fender during full lock and it would be bad at all.
Old Nov 2, 2006 | 11:11 AM
FalkenSiR's Avatar
Default Re: ------> you think i'll rub with my setup? (dvp)
At that ride height, you'll be fine. If anything, at full turn, you might rub in the front. And that would be in the outer side, not inner. Lots of misinformation in this thread.
J.nguyen
Honda S2000
Feb 14, 2008 04:17 PM
JjuuN R
Jul 4, 2007 04:08 PM
msinsky14
Dec 19, 2006 04:07 PM
sebmour jdm
Honda S2000
11
May 27, 2005 02:27 PM
TrueZen
Jul 31, 2003 10:44 PM
