best frankenstein engine
what about a stroked b20 with ctr head ? 2.4liter with ported head would be pretty nasty
i know b20 with ported non ctr head and ITB's makes 246 whp, seen it in a DA drove it too....madd ***** and really snappy response
Modified by hondalover91crx at 7:49 PM 10/30/2006
there are so many differnet engines that you can swap. just search around.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondalover91crx »</TD></TR><TR><TD CLASS="quote">what about a stroked b20 with btr head ? 2.4liter with ported head would be pretty nasty
i know b20 with ported non ctr head and ITB's makes 246 whp, seen it in a DA drove it too....madd ***** and really snappy response</TD></TR></TABLE>
what the hell is a non ported ctr head
I have a b16 head with a bad valve (which im fixing). I was thinking of using it a frankenstein swap. My question is whats a better bottom end to use... B18B or B20? Pros and Cons of each?
Sorry if Im jacking the thread
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tEKnics »</TD></TR><TR><TD CLASS="quote">I have a b16 head with a bad valve (which im fixing). I was thinking of using it a frankenstein swap. My question is whats a better bottom end to use... B18B or B20? Pros and Cons of each?
Sorry if Im jacking the thread</TD></TR></TABLE>
Same ******* block except the B20's bored more (1/5 of liter more)
And since they are bored a little bit more there is a little less sleeve strenght.
I dislike B20's alot, because people are CRAZY about them when a B18 is way more stable, easier to find, and cheaper.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fmrprojects »</TD></TR><TR><TD CLASS="quote">what the hell is a non ported ctr head</TD></TR></TABLE>
ported (pause) NON ctr head, meaning the kid had a non ctr head ported by a private company, the ctr heads are ported by honda, thus in the end meaning, i dont know if ctr head would have created more power, but this is what he got when a private company did it. hope that clears it up
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lodo »</TD></TR><TR><TD CLASS="quote">b18 and b20 blocks are the same besides the bore. thats the only dif. you use the same rods for either engine.</TD></TR></TABLE>
just to add**
the b20 sleeves are combined together.. other then the sleeves being diff. there similar blocks.
just to add**
xEnderx
Jul 28, 2005 07:41 AM
