car idles high what to do
Old Oct 29, 2006 | 06:44 PM
jdmeg61's Avatar
Default car idles high what to do
my car has a b16a in it i switched out the intake manifold to a skunk 2 thats all i did and i changed the coolant cause it all came out when i took out the old manifold now it idles at like 4000 rpm any ideas what i can do or what it might be
Old Oct 29, 2006 | 06:49 PM
Lord Helmet's Avatar
Default Re: car idles high what to do (jdmeg61)
used a new intake manifold gasket and throttle body gasket when you replaced the stock one? all the vacuum lines plugged in yet? bleed the cooling system yet? blah blah blah, etc....
Old Oct 29, 2006 | 06:55 PM
Max Kling's Avatar
^^ lol yea no ****.
Spray some carb cleaner all around your intake manifold and I bet you it will idle even HIGHER.
Old Oct 29, 2006 | 08:12 PM
k20EP3's Avatar
Default Re: (Max Kling)
yeah check all that but also since you changed your manifold id check your throtle cable it might be to tight or something along those lines...♠
BIGef
13
Oct 27, 2012 12:25 PM
Lilsoldierbenny
Apr 16, 2010 07:27 AM
Curt91
May 24, 2007 05:22 PM
matto2413
Jun 1, 2005 11:36 PM
laughinxxx
Mar 31, 2002 09:49 PM
