My first K swap
Ive decided to do my first K swap. im putting in a k20a2. im buying the complete change over from hmotorsonline.com and heres what it comes with
- Motor
- Hydraulic Tranny
- ECU (PRB)
- Axles with Half Shaft
- Shift Cables
- Stock Motor Mounts *
- Alternator
- Starter
- Clutch
- Flywheel
- Intake Manifold
- Exhaust Manifold
- Fuel Rail
- Injectors
- Coils
- Engine Harness
- Comes With All Sensors Needed
so far i think i only need these things
1. Mounts
2. Header
3. Axles
4. Harness
5. ECU
6. Fuel system
7. Radiator and hoses
8. Shifter Box
9. Coolant temp sensor/Fan switch
10. Intake
11. Mid Pipe
12. Shifter Cables
13. Throttle cable
14. Shifter linkage Clips
15. EP3 pulley and belt
Am i missing anything? Can anyone give me some good places where to buy these? i think i got just about everything, and it looks like i can get pretty much everything from hybrid racing so far.
- Motor
- Hydraulic Tranny
- ECU (PRB)
- Shift Cables
- Alternator
- Starter
- Clutch
- Flywheel
- Intake Manifold
- Exhaust Manifold
- Fuel Rail
- Injectors
- Coils
- Engine Harness
1. Mounts
2. Header
3. Axles
4. Harness
5. ECU
6. Fuel system
8. Shifter Box
10. Intake
11. Mid Pipe
12. Shifter Cables
13. Throttle cable
i take it since no one posted that im missing any parts i pretty much got the list down. please share if i am though. theres nothing worse than almost finishing my swap and realize i dont have a part.
you will need the karcepts shifter box mount that makes it so you don't need to cut holes below cd player or wherever depending on vehicle i'm guessing civic, this is hondatech. This makes your interior look better
besides this lots of time and patience, a welding machine umm creativity good luck post some pics if you can
it would also help if you said what you are putting it in, more people would know what to tell you and you can also look in Hybrid forum they have lots of info but search first
oh haha i could have swore i put the car i was putting it in. im putting it in a eg hatch this coming summer as soon as i work up enough money for the parts and motor. sorry about that.
Jerry31
Jul 4, 2004 11:32 AM
