wheel spacer question
The Integra Type R has a 5x114.3 bolt pattern.
Beware, the spacers may move the wheels to the outside of the wheel wells where they will rub against the fenders. You're better off replacing the hubs.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lambertincorp »</TD></TR><TR><TD CLASS="quote">hmmm where did u see </TD></TR></TABLE>
http://page3.auctions.yahoo.co...04639
$190 per pair in 10mm to be exact
these are 4x114.3---->5x114.3 adapters
i would reccomend buying the right pattern wheel for your car, though
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tr1plesix. »</TD></TR><TR><TD CLASS="quote">Of course with these spacers, you need wheels with the extra holes in between the lug holes or else the original studs will touch the back of the wheel
No. This is wrong. If you look at the pic they come with special shorter studs and special flush with the surface of the spacer. If the rims came with the extra holes there would be no need for a conversion now would there?
For the record; I would do this. I don't trust the strength and integrity of such a set up. Just get knock off rims that are the right bolt pattern or do the conversion.
Cheers.
</TD></TR></TABLE>No. This is wrong. If you look at the pic they come with special shorter studs and special flush with the surface of the spacer. If the rims came with the extra holes there would be no need for a conversion now would there?
Cheers.
</TD></TR></TABLE>yeah... that's why most aftermarket wheels have them so they can use spacers
but old man neri is correct..some adapters require the holes in between the lug holes on the back of the hub and some do not.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by old man neri »</TD></TR><TR><TD CLASS="quote">Just get knock off rims that are the right bolt pattern or do the conversion.</TD></TR></TABLE>
If you're looking for four-lug rims that look like the ones on the Type R, click here.
carl_aka_carlos
19
Sep 14, 2005 07:36 AM
