92 accord wire diagram
hey guys anyone know what wire it is for the headlights.I looked it up in the book but it says one hting and once i wire it is then the horn goes off.I am trying to hook up fog lights and just need to know the wire color for the headlights so the fogs go on with the headlights.Thanks in advance.
i need to know what area you are looking to hook this up.
I would reccomend that you but a Honda harness alone so that you can hook them up the 100% right way (they are sold seperately).
But if you insist on doing it this way you should install a power relay so that you can draw power from the battery and use the headlight wire to turn it on. This will help you avoid blowing the fuse.
just let me know in what general area you want to wire it up
