no spark at all
Old Oct 29, 2006 | 01:16 PM
ironryder's Avatar
Default no spark at all
hi all,my car was running today and it just die out when i hit the gas after backing out of my drive way.
now it will crank but won't start,i pull the plugs and i see fuel,but no spark at all.
what are some of the common cause for not getting spark?
thanks
Old Oct 29, 2006 | 01:43 PM
B18bEG6ick's Avatar
Default Re: no spark at all (ironryder)
what year is the car?? usually the coil goes bad on the early civic's (92-95), from what i have exprience with.
Old Oct 29, 2006 | 02:07 PM
paqman's Avatar
Default Re: no spark at all (B18bEG6ick)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">usually the coil goes bad </TD></TR></TABLE>
I second that one. I had a similar problem and I diagnosed a faulty coil and igniter. They are located inside the distributor assembly. Expect to spend around $100 USD for these two parts. I got mine at a local parts supplier and they came with a lifetime warranty.
This article off of G2IC might help you out huge!
Replace Igniter / Coil DIY
homer_eps
12
Apr 9, 2008 08:09 PM
coldpimpin
Apr 10, 2007 08:41 PM
candyteggy
Nov 10, 2006 02:32 PM
BadBeck
Dec 11, 2003 05:59 PM
Lo-Buck EF
Jun 2, 2003 12:09 PM
