Well I think my LSD is shot! What do you think?
Old May 6, 2002 | 10:05 AM
01PYTypeR#1140's Avatar
From: Couple SW99 40 Cal. For Ya, Do Ya Really Want It.., NJ, U.S.A
Default Well I think my LSD is shot! What do you think?
Last night I noticed this rattling sound in my front end as soon as I put a load on the car in first or reverse, I hear it sometimes when braking hard, and If I'm crusing and play with the gas peddle in a quick tapping motion I hear it as well. At first I thought it was coming from my drivers side axle, then after a friend helped me look into it we noticed the same identical sound from both sides. I pulled off both front wheels and checked axles, bushing, balljoints, and so on, but nothing obvious. Thats when someone said their prelude SH made the same noises when his LSD went bad. I'll be leaving the R off at Acura thursday to get it checked out. I hope they don't leave me with some rental for to long, because I've heard some horror stories and this could take a few weeks to straighten out. And yes I checked the cat., and the brakes they both seem fine. The noise is clearly coming from directly behind the two front rims.
Old May 6, 2002 | 10:20 AM
Sleeper 4X4 F150's Avatar
New User
Default Re: Well I think my LSD is shot! What do you think? (01PYTypeR#1140)
I was gonna say axles. But if you checked them and they're ok. I'd say it's probably internal.
Old May 6, 2002 | 10:26 AM
Default Re: Well I think my LSD is shot! What do you think? (Buzzsaw)
Boots aren't torn, they don't click when turning or going straight. Only makes the noise when there's a load such as braking hard, taking off from a stop and Playing with the gas while moving in a fast taping motion.
Old May 6, 2002 | 10:28 AM
sgT's Avatar
sgT
prelude SH doesnt have an LSD.
Old May 6, 2002 | 10:34 AM
Default Re: Well I think my LSD is shot! What do you think? (sgT)
Yes they do!
Old May 6, 2002 | 10:35 AM
sgT's Avatar
sgT
NO, they dont.
It isnt anything like a conventional differential.
Old May 6, 2002 | 10:37 AM
Lip's Avatar
Lip
nope
Old May 6, 2002 | 10:39 AM
sgT's Avatar
sgT
I will try to explain it to you.
The diff in an SH is composed of an inner part and outer part. They are not
connected in any way, one just turns inside the other. The trans drives the ring
gear, which turns the outer part, which in turn drives the ATTS unit.
That biases the power and turns the inner part of the diff which drives the axle.
Old May 6, 2002 | 10:41 AM
b00st-0wnz's Avatar
From: Drinking Beer in sunny FL and jamming to Skid Row, USA
-Dave, +1
Old May 6, 2002 | 10:43 AM
Sorry! So i'm wrong I was told different. Now back to the topic. Based on the symptons I described does it sound like it could be the LSD or does anything else come to mind?
[Modified by 01PYTypeR#1140, 2:47 PM 5/6/2002]
Old May 6, 2002 | 10:44 AM
Rodney's Avatar
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
Default Re: Well I think my LSD is shot! What do you think? (FL n NC rock j00)
ATTS= , ATS=
Old May 6, 2002 | 10:46 AM
sgT's Avatar
sgT
remove both axles and inspect the CV joints
Old May 6, 2002 | 10:52 AM
I don't want to get that into it, because Acura will have it this thurday. Anyway I just wanted to get a idea of what I was up against. Thanks I hope it's something other than the LSD. Now I can rest a little with the hope that it's not as bad as I thought.
Old May 6, 2002 | 01:37 PM
Track rat's Avatar
Torn or sloppy motor mounts?
Old May 6, 2002 | 01:42 PM
Keane Rated R's Avatar
Default Re: Well I think my LSD is shot! What do you think? (Track rat)
broken LSD is LOUD! I know by experience, when I busted mine, there was alot of loud wrangling under 100kmh but nothing over 100kmh.. damn I hated that sound
Old May 6, 2002 | 04:55 PM
owen_the_soyboy's Avatar
clutch spring/springs broken and loose? that is what happened to me...
has shifting gotten any harder?
metal tin can rattle? clutch springs/pressure plate are/is toast/loose
Old May 6, 2002 | 05:59 PM
I put the car under a load with the hood up and the motor mounts are fine the noise I get is right behind both rims, that's why I was thinking axles or LSD.
Old May 6, 2002 | 06:02 PM
Default Re: Well I think my LSD is shot! What do you think? (Integra Rated R)
That sounds exactly like my situation.
Old May 6, 2002 | 06:04 PM
Dropspeed's Avatar
Or clutch, the stock ITR clutchs has been know to have problems in the past.
P.S. I'm not trying to be an *** but could you flatten out your sig paragraph style instead of line by line. It makes it hard to scrole through 17+ lines of sig evertime you post. If you don't what to so be it.
Old May 6, 2002 | 06:05 PM
Default Re: Well I think my LSD is shot! What do you think? (owen_the_soyboy)
Shifting is no different than usual, but this is very possible!
Old May 6, 2002 | 06:21 PM
Dropspeed's Avatar
Much easier to read the post.
Thanks Mattj
Old May 6, 2002 | 08:27 PM
Jisatsu B18EK's Avatar
Default Re: Well I think my LSD is shot! What do you think? (Dropspeed)
My guess on this is a bad throwout bearing on your clutch. My daily driver had this happening to it for a while and when i finally got around to replacing it, it had torn up the tranny too. It was making a rattling noise when the clutch was disengaged and disappeared when i put the clutch in. Not to mention when you let it out slowly in any gear and kinda just give it half thorttle, you'd hear the nasty rattling sound. From my experience, a busted LSD would be a LOT more then a slight rattling sound. Just my $0.02
Old May 7, 2002 | 03:55 AM
Default Re: Well I think my LSD is shot! What do you think? (Jisatsu B18EK)
if it is the LSD dont drive your car around much, you will eventually break the gearbox. The LSD should fall under warranty so let the dealership check it, they had mine car in and out for a few months before they found out it was the LSD
Old May 7, 2002 | 01:32 PM
Did I say light rattle, listening to it again I've come to the conclusion that it's LOUD AS HELL!
arsalanshj
Sep 16, 2012 11:11 PM
jdmcivicracer89
Nov 13, 2007 10:32 AM
hondapwr
24
May 19, 2005 01:39 PM
