Suspension & Brakes Theory, alignment, spring rates....
Crunch or knock at full steering lock
Old Oct 29, 2006 | 09:57 AM
slow_dx's Avatar
Default Crunch or knock at full steering lock
I have a 2000 civic hatch, and whenever I make a U-Turn (steering at full lock) I hear a single, loud 'crunch' noise. It doesn't repeat. This happens even at very low speeds.
Any idea on what this could be?
The car is lowered, but it is not extremely low -- maybe .75" lower than stock?
Old Oct 29, 2006 | 11:32 AM
dvp's Avatar
dvp
Default Re: Crunch or knock at full steering lock (slow_dx)
Do you have the upper arms whiched around? Left on the right side and vise versa. If so that's the problem.
Old Oct 29, 2006 | 11:42 AM
slow_dx's Avatar
Default Re: Crunch or knock at full steering lock (dvp)
No, the upper arms are factory; they've never been off the car.
Old Oct 29, 2006 | 12:48 PM
dvp's Avatar
dvp
Whats been done to the suspension other than it just being lowered?
Old Oct 29, 2006 | 05:13 PM
slow_dx's Avatar
Ground control coilovers & iluminas. Stock knuckles, stock control arms, no sway bars.
I removed the passenger side knuckle once, and the passenger side lower balljoint was replaced.
Old Oct 29, 2006 | 06:57 PM
dvp's Avatar
dvp
Did you get under there and make sure everything was tight? Most guys just go right for the forum instead of looking first.
Old Oct 30, 2006 | 08:05 AM
slow_dx's Avatar
I checked everything when I put my snows on two weeks ago. Also retorqued the lug nuts last weekend.
ChrisGSR
Jul 18, 2006 03:05 PM
Yellowone
Apr 6, 2006 05:30 PM
LSV_REX
Mar 31, 2006 12:36 PM
kouisan
Jul 29, 2002 02:43 PM
