- Doing a Compression Test.. No timing Belt.. some Q's -
So my timing snapped on me when i was just sitting still idling. I have the tools to do a compression test, but I was reading on H-T just to do the compression test without the timing. My question is, will it be okay to crank the car and what not without having a timing belt installed, or do I have to install the timing belt just to see what my compression is... I want to check if my valves are screwed.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Skunk.Werks »</TD></TR><TR><TD CLASS="quote">hahah, dude you can't check compression without a timing belt.</TD></TR></TABLE>
thats what i thought.. read differently on a thread,
me for listening
me for listening
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RockLee` »</TD></TR><TR><TD CLASS="quote">will it be okay to crank the car and what not without having a timing belt installed, or do I have to install the timing belt just to see what my compression is... I want to check if my valves are screwed.</TD></TR></TABLE>
yeah, if your valves aren't screwed now, they will be when you crank the engine without a timing belt.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ddd4114 »</TD></TR><TR><TD CLASS="quote">
yeah, if your valves aren't screwed now, they will be when you crank the engine without a timing belt.</TD></TR></TABLE>
oh, my valves are screwed then
