lug nut broke in half!! rim stuck on
hello everyone, i need some help. i was in the process of rotating my tires and when i was taking the right passenger lugs off one wouldnt turn as well so i was trying to loosen it the lug snapped in half leaving my rim stuck on. I cant get behind the rim to the stud. is there any way to get this off without sacraficing the rim?
lugs are motegi 12mm
heres some pics.
[IMG]
[img][IMG]
any help would be great!!!
heres some pics.
[IMG]
[img][IMG]
remove teh upper A arm, lower ball joints, pop the axle, front fork, disconect brake lien from caliper, and what ever else im forgetting to remove the front spindle from the car. you can get to the back of the stud. either weld it if its looose, or drip it out with a settaline torch, wheel is ok, youll need a new hub though. had to do this a month ago when i spun a lug in the spindle
Try a bolt remover like the ones from Sears.
I've also used a socket and pounded it on and removed the bolt that way.
Or a hammer and a chisle but you'll more than likely destroy the threads that way.
just had this problem....i removed the whole suspetion and axel (this made sence because at the time i was doign a tranny swap) then i bouthgt soem nice carbine drill bits $$$ and got an air chicell and knocked back of the stud off...good luck man this was a head ache for me
Same thing happened to me on my old 240sx with the same exact style lugs. Drilled it out while still on the car and only took 10 mins or so. All you have to do is drill it far enough that it clears the remaining piece of the lug and then kick your tire and it should just fall off.
They sell these sockets where the inside is like a swirl and when used on an impact gun it sort of threads itself into broken or stripped bolts and takes them out. Go to local shops and see if thay can take it off for you.
koolkevin1107
12
Nov 11, 2005 04:45 AM
JDM_ITR
Sep 11, 2002 09:12 AM
