FS: Honda Hx Rims in Upstate Central NY
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondahybrids »</TD></TR><TR><TD CLASS="quote"> As most of us know, 4x100 bolt pattern, meaning it will fit almost ANY Honda 4 lug, '85-'00( but will not fit Integras). </TD></TR></TABLE>
This is not true, all integras except type r's have the same lug pattern as civics. This is why so many civics have integra rims, ie blades, meshes and fat fives.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by killercannible »</TD></TR><TR><TD CLASS="quote">
This is not true, all integras except type r's have the same lug pattern as civics. This is why so many civics have integra rims, ie blades, meshes and fat fives. </TD></TR></TABLE>
Uhh it is true. Yes non Type R Integras have the same bolt pattern as a Civic, BUT, If you knew anything you would know that these rims will not clear Integra calipers.
If they won't clear higher trim level Civics (Ex/SI) stock brakes, how would they clear Integra's?
Bumped TTT.
Bumped TTT.
i have a 97 ex with si disc conversion and those rims, along with the 14's that came on my car clear the calipers fine. All rs and most ls integras come with 14 inch steel rims also so explain your point again because it makes no sense.
Ok..first do some research and others will tell you.
https://honda-tech.com/zerothread?id=1609706
The spokes come in MUCH closer/ have a different offset than any Honda stock 14" rim. With the different offset they are not as deep on the inside as other rims therefore there is less room!
They did not fit on the front of my '94 Civic EX, my finacee's '97 EX or my '95 Integra, ALL have stock brakes. However i was able to fit stock steelies on my Integra, '89 Accord Alloy rims on the '97 Civic and 90-91 Crx Si rims on the '94 Civic. How is that possible you ask, all of those other rims mentioned above are more "open", they have a smaller offset which allows them more room to clear the caliper. Like i said before, you will have to grind the bracket a little bit OR get a wheel spacer.
Civic Ex/SI's & Integras all have larger ( 10.3") front brakes than the lower trim level Dx, Lx, Cx, Vx and yes, even the HX.
Does that explain it better?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vestalfootball72 »</TD></TR><TR><TD CLASS="quote">Hey man im located in Binghamton- i want those wheels PM me - thanks </TD></TR></TABLE>
Ok, you've been Pm'ed...
Bump for ppl with cash money OR.....
Will also consider trades.
Looking for '96 Integra GSR/Se Rims aka "the sunflower" style with tires if possible
or
97-01 Integra LS "Mesh" wheels with tires if possible.
If you have either set of these rims with tires and are interested in a trade, we can work something out.
or
