B18C1 INTO MY 95 COUPE
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Orangedragone »</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread?id=856396</TD></TR></TABLE>
Just get a B16A it is easier to swap into the EH/EJ chasis. With a B18C1 you will have more wiring to do. But you do what you want not what I suggest. I only recommended The B16A cuz I just put one in my 92 hatch. It was by far the easiest swap I have ever done.
Either way if you want to do the B18C1 you'll need the following:
Motor
Tranny
Ecu (P72) OBD I
Shift linkage (from any Integra '94-'01)
Axles (same as above)
Mounts (same a above)
Soldering gun
Heat shrink tube
Wire strippers/crimpers
Torque wrench 0-100 lb/ft
Ball joint breaker
Air tools with 32mm socket for the axle nuts
Hand tools mostly 10,12,14, and 17mm wrenches and sockets
Extra lengths of 18-22 guage wire
Pinout diagram from http://www.ff-squad.com
hammer
pry bar
some kind of long 1/4 inch diameter punch type thing for the shift linkage
I also recommend getting the "Honda Engine Swaps" book by Aaron Bonk. You can find this on any site that sells automotive books, or at Barnes and noble. I also recommend bagging and tagging your parts during disassembly. It will seem very tedious but will actually save time during re-assembly. Any questions?
Motor
Tranny
Ecu (P72) OBD I
Soldering gun
Heat shrink tube
Ball joint breaker
hammer
pry bar
I realize that. I also have the ECU pinouts printed, so don't tell me to search. I'm not the one askin the question. Like I said earlier it was a SUGGESTION, hes gonna do what he wants to do.
um, i have no idea what eg6ls is talking about.
i've done both swaps, the b16 was jdm and it was more of a hassle.... but not anything extreme.
with my b18c into my vx it was simply swapping some wires around. OBD2 b18c in obd1 vx, piece o cake.
i think i took more time doing my rear disc conversion then the swap..
95xEJ1
Mar 23, 2011 11:32 AM
nanagsr
Mar 9, 2009 03:00 AM
