Hondata Intake manifold gasket.
Old Oct 28, 2006 | 06:22 PM
turnsignalandy's Avatar
Default Hondata Intake manifold gasket.
Ive read bout people recomendin the Hondata Heatshield IM Gasket to other People. Whats the purpose of it? How does it help?
Old Oct 28, 2006 | 06:32 PM
shibiku's Avatar
Default Re: Hondata Intake manifold gasket. (turnsignalandy)
search
Old Oct 28, 2006 | 06:35 PM
THC07's Avatar
The gasket helps keep away heat transfer. the heat dissipates out of the gasket before it get to the Intake manifold. wanna keep the air in the IM as cold as you can.
Old Oct 28, 2006 | 06:38 PM
blub18's Avatar
http://www.hondata.com/heatshieldgasket.html
Old Oct 28, 2006 | 07:35 PM
Default Re: Hondata Intake manifold gasket. (blub18)
anyone notice power increase from this?
Old Oct 29, 2006 | 05:03 PM
THC07's Avatar
Before, my IM would be hot enought that i could not hold onto it.
with the thermal gasket i can keep my hand on the IM, id say about 10-15 degrees
Old Oct 29, 2006 | 05:13 PM
jadugartir's Avatar
Default Re: Hondata Intake manifold gasket. (THC1107)
its blue. and its pretty.
but seriously, it keeps your intake air cooler. cooler air is denser air, which means more oxygen for every spark which can only mean a stronger running car.
Old Oct 30, 2006 | 03:45 PM
NA JDM GSR's Avatar
Default Re: Hondata Intake manifold gasket. (jadugartir)
y cant we just use a cold air intake
Old Oct 30, 2006 | 04:39 PM
cambopheonix56's Avatar
Default Re: Hondata Intake manifold gasket. (NA JDM GSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NA JDM GSR &raquo;</TD></TR><TR><TD CLASS="quote">y cant we just use a cold air intake </TD></TR></TABLE>
Ehh, what
Old Oct 30, 2006 | 04:44 PM
TurboTagTeam's Avatar
Default Re: Hondata Intake manifold gasket. (cambopheonix56)
Cold intake air + hot manifold = hot air
Cold intake air + cold intake manifold = cool air
Thats why
Old Oct 30, 2006 | 04:51 PM
NonovUrbizniz's Avatar
Loved
Unless you bypass ALL the coolant lines to the intake manifold I don't think that thing won't do much if anything...
The throttle body and intake manifold are heated.
Also not sure about the hondata one but whatever you get make sure that there are heatshielded washers too... otherwise the heat will soak through the bolts.
Frankly for how much of a pita it is to take off the intake manifold I don't see the value in doing it unless you're taking of the intake for somthing else...
I thought about doing one when I did my y8 intake manifold swap but I was running low on money and had no plans to bypass the coolant lines to the intake.
Take all of the above with a grain of salt though as obviously the majority of heat soak will come from the head... although again the direct connection may be broken but the radiant effect heat is still there.
Vtec04
Jul 20, 2017 04:01 AM
949
Apr 7, 2009 08:04 AM
blackeg
34
Sep 10, 2003 12:39 PM
DanielLaruso
Feb 4, 2003 05:28 AM
ragejed
Dec 25, 2002 10:34 AM
