k20a or k24
Old Oct 28, 2006 | 03:12 PM
decepticon35's Avatar
Default k20a or k24
i have an ep3, i thinking bout doing an engine swap, read up about the k20a type r engine which is beautiful but i think is hard to get, but i also heard someone talking bout puttin a k24 into his rsx, would that fit in an ep3. which engine is stronger cus i saw that both knock out bout 220 hp.
Old Oct 28, 2006 | 03:23 PM
KOREAN's Avatar
Default Re: k20a or k24 (decepticon35)
You can fit both into an ep3. The k24 swap needs a little bit more work, but it's possible. Also, don't forget that hp isn't everything! The k24 has more torque.
Old Oct 28, 2006 | 03:30 PM
Default Re: k20a or k24 (korean)
ok , so are you saying that the k24 would be the better engine because of the torque?
Old Oct 28, 2006 | 08:16 PM
BarracksSi's Avatar
They're both good. The guys who run them are mainly saying that the K24 is better for around town, K20 for high-speed work.
Here's what I've been thinking while trying to decide what I want to put into my own EP...
The 2-liter motors (k20a2, k20a) need to be revved higher to really make them sing. Of course, they can rev higher, and I could easily use the shorter 6-speed tranny and get more acceleration.
The K24 blocks can't rev as high; the longer stroke means that piston speeds will go as high as a K20 at lower engine RPMs. They can be built up internally to rev higher, of course, but I'm not sure if I want to sink that kind of money into a motor when I don't have race sponsorship or gobs of cash to play with. I would rather use a <u>5-speed</u> tranny with a K24 because of that lower redline. However, they do have a bunch more torque, and can easily make up for the taller 5-spd gearing.
So, again, I'd say that they're both good at what they do. I'd also use them without boost -- leave turbos & blowers for the lower-compression K motors.
Slow_si(8th)
Honda Civic (2006 - 2015)
Jun 12, 2024 04:52 PM
RAWR
14
Dec 11, 2004 08:58 PM
SuspectProduct
Jul 19, 2001 10:10 PM
ebyak
May 22, 2001 08:59 PM
ebyak
May 21, 2001 08:58 AM
