1997 Civic CX Engine Noise
Old May 6, 2002 | 08:17 AM
allenp's Avatar
Default 1997 Civic CX Engine Noise
A colleague of mine owns a 1997 CX (hatch), I believe the B16 motor. It has 100K+ miles.
He hears a "ticking/knocking" sound that is very noticeable when cold and then gradually quiets. He's not sure if it ever completely goes away. It's been growing worse for 3 years -- apparently it started out as a slight tick, now it more closely resembles a knock.
Any thoughts? Is this a mechanical or hydraulic lifter in this motor?
Thanks much.
Old May 7, 2002 | 04:47 AM
allenp's Avatar
Default Re: 1997 Civic CX Engine Noise (allenp)
ttt
Old May 7, 2002 | 04:49 AM
hybridreams's Avatar
When's the last time the valves were adjusted?
Old May 7, 2002 | 06:14 AM
Inigo Montoya's Avatar
Default Re: 1997 Civic CX Engine Noise (hybridreams)
I agree, a valve adjustment would probably fix this ticking.
Old May 7, 2002 | 08:02 AM
allenp's Avatar
Default Re: 1997 Civic CX Engine Noise (inigo9910)
That was checked -- it doesn't appear to be that.
Plus, the sound grows worse under load/low RPM -- for example, when you launch, the sound becomes more distinct... Perhaps detonation, piston slap, wrist pin??
Old May 7, 2002 | 09:11 AM
speedillusion's Avatar
New User
hhhmmm... how about ticking injectors? bad onjector seals? or bad injectors?
Old May 7, 2002 | 12:52 PM
Turb0Minnow's Avatar
Default Re: 1997 Civic CX Engine Noise (midnitekreeper)
are u using 5w-30 oil? some preludes at startup sound like someone threw a hand full of rocks into the valve cover. maybe ur problem got me.
Old May 8, 2002 | 10:30 AM
New User
try using the stethoscopes mechanics use... if you can get hold of one. it'll be easier for you to pinpoint the problem
Old May 8, 2002 | 10:49 AM
RedHatch's Avatar
Doesn't the cx come with a d16?
Old May 8, 2002 | 12:07 PM
Ricey McRicerton's Avatar
Default Re: 1997 Civic CX Engine Noise (RedHatch)
d15 i believe
umby
Jan 27, 2010 06:24 AM
whiteboy-dc4
Feb 13, 2009 01:31 PM
imonx850
Nov 2, 2004 10:53 PM
Rev-Olution
Sep 4, 2003 09:11 PM
lonefuzzy79
Jan 8, 2003 03:29 PM
