6gen 2000 accord gasker and VTEC - Need Help badly
Old Oct 28, 2006 | 12:54 PM
ujhonda's Avatar
Default 6gen 2000 accord gasker and VTEC - Need Help badly
He everyone:
Here is the story - 1st of all its a 2000 accord 4cyl -vtec 187K on it
so my Gasket blew - then I gave my car to a local shop to fix it, yes thy remove the cylinder Head, send it to machine shop to shave a bit, put a new Gasket and installed it.
they also replace the radiator due to oil contamination - fine
everything almost back to normal, no more oil in the Rad, or Overheat issue.
but my engine vibrate so much with unusual noise - tech working on the car told me go drive couple of day and call me - I said ok
alright I was driving around 25 minutes - bamm check engine light came. well I came to the Hondatech here - use how to checkengine code out - yes I pull the code it is 22 = P1257, P1258, P1259 means VTEC.
at this point I would like to fix it my self - but before I jump in to water, can one of you kind Honda Guru help me.
is it normal to vibrate, the engine due to VTEC problem ?
or our tech over here did something wrong with the timing and balancer belt, should I check them too?
man thats gonna be lots of work.
I am not a good writer, so forgive me - dudes
Thank you so much in Advance.
ujhonda
Old Oct 28, 2006 | 02:36 PM
H2290's Avatar
Default Re: 6gen 2000 accord gasker and VTEC - Need Help badly (ujhonda)
It is possible he did not set the timing correctly or something.
Take it Back.
Old Oct 28, 2006 | 03:44 PM
ujhonda's Avatar
Default Re: 6gen 2000 accord gasker and VTEC - Need Help badly (H2290)
Thanks H2290;
but if its timing problem, I should also get piston miss firing - code right ?
I check the VTEC solenoid with a ohm meter and check the voltage yes everything good, but I didn't check if its clogged - its too dark here, I will check that tomorrow.
I am really glad that, we have Honda-tech form
ujhonda
Old Oct 28, 2006 | 04:11 PM
ujhonda's Avatar
bump
Old Oct 30, 2006 | 02:07 PM
ujhonda's Avatar
Ok I removed the VTEC solenoid - clean everything, check with the ohm meter - installed it. yep its working, no more check engine light.
but I still have some vibration - look like my balancer bet, technician didn't install properly.
I am looking to it tomorrow
if any of you have helpful info please give it to me
Thanks
Jeff Miller
Feb 24, 2018 05:06 PM
amaidendevil
May 16, 2016 01:24 PM
dwr1977
Jan 28, 2012 07:04 AM
androide016
Jun 20, 2010 04:18 PM
5Zigen Accord EX
Sep 16, 2006 10:12 PM
