how to swap a d16z6....
Old Oct 28, 2006 | 12:38 PM
B16 IIgen's Avatar
Default how to swap a d16z6....
i need specifics onhow to swap a d16z6 into a 94' civic dx coupe.....
Old Oct 28, 2006 | 01:04 PM
B16 IIgen's Avatar
Default Re: how to swap a d16z6.... (DX94')
HOW!!!!! I NEED HELP
Old Oct 28, 2006 | 01:06 PM
over_'s Avatar
put it in, plug it in. Plug in ECU. Add fluids...thats it
Old Oct 28, 2006 | 01:08 PM
B16 IIgen's Avatar
Default Re: (OVNI_CIVIC)
more specific like in steps
Old Oct 28, 2006 | 01:21 PM
FastAsleep's Avatar
Default Re: (DX94')
if after searching through the largest online resource for hondas you still don't know, i suggest you pay someone to do it for you.
Old Oct 28, 2006 | 02:35 PM
northkai3's Avatar
Default Re: (FastAsleep)
it is plug and play, if you dont know how to remove and install a motor you should prob pay someone. where do u live? i could do it
Old Oct 28, 2006 | 02:36 PM
northkai3's Avatar
Default Re: (northkai3)
nm oregon
Old Oct 28, 2006 | 02:41 PM
Archidictus's Avatar
Unceasing Measure
Default Re: (DX94')
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DX94’ &raquo;</TD></TR><TR><TD CLASS="quote">more specific like in steps</TD></TR></TABLE>
unplug wiring harness, drain cooling system, undo shift linkage, remove axles, undo mounts, remove engine.
Installation is the reverse. Enjoy
Old Oct 28, 2006 | 05:59 PM
[Eg.6]LiLbOy916's Avatar
Default Re: (Archidictus)
Pretty much it
Old Oct 28, 2006 | 06:08 PM
BlueIntegraBoy's Avatar
You guys forgot that he needs to run two wires (VTEC solenoid and pressure switch) to the ECU plugs
Old Oct 28, 2006 | 06:10 PM
he had another post that said he was goin to do that already
SCMFOX
May 16, 2019 10:37 PM
B16 IIgen
12
Oct 28, 2006 06:38 PM
d15vtec94
Dec 20, 2004 03:00 PM
Tyreece04
May 10, 2004 04:38 PM
yusoslo
Apr 13, 2003 09:43 AM
