D16Y7 maybe ?
Old Oct 28, 2006 | 12:05 PM
arcboy's Avatar
New User
Default D16Y7 maybe ?
I have a 97 DX and the engine says it is a D16Y7 which as I understand is non-vtec which has 205,000. For some reason it sounds like it does. It makes some vtec noise at certain rpms, only when the clutch is disengaged. The wierd thing is that sometimes the so called vtec noise is always on and sometimes not. I drove 100 miles today and it is just under 3/4 tank. It seems like terrible MPG.
Old Oct 28, 2006 | 12:41 PM
imaginAZN's Avatar
64.175.64.11
any car that you floor it make a loud sound o_O i also have a d16y7 but im guessing you're smashing the gas all the time? o_o
Old Oct 28, 2006 | 01:03 PM
turboDeznutz's Avatar
Default Re: (imaginAZN)
y7 ftw
Old Oct 29, 2006 | 05:10 AM
arcboy's Avatar
New User
no not flooring it all the time. it makes the noise under normal accerlation at low rpms. and it sometimes doesn't do it at low rpms but at say the vtec rpm level, I don't have a tach but it is a guess of 4something rpm. the noise sounds like a broke vtec.
I am I correct on the car not having vtec? could this be a rattle or something?
Old Oct 29, 2006 | 05:38 AM
nightkidsi's Avatar
Default Re: (arcboy)
I have the same motor but when i floor it i get a high whissleing sound around guessing 5 or 6k (also dont have a tach) and it happends everytime. as for vtec it is not but its probably a belt or somthing creating the noise when you accelerate at that certain point.
bryan
Old Oct 29, 2006 | 05:43 AM
TurboTagTeam's Avatar
Default Re: D16Y7 maybe ? (arcboy)
d16Y7==Single cam NON V-TEC
You don't have V-Tec
Old Oct 29, 2006 | 05:59 AM
John M's Avatar
Default Re: D16Y7 maybe ? (TurboTagTeam)
No vtec for you man,
Old Oct 29, 2006 | 06:11 AM
OMG naD16 lol's Avatar
its all in your head, you want the vtec, but you dont have vtec, plus in a sohc, one can not hear or feel vtec, unless there has been a bit of work done to the vehicle
Old Oct 29, 2006 | 06:51 AM
arcboy's Avatar
New User
so than I am thinking of swapping it out. What is the best vtec swap. I just need a sohc vtec motor and 5-speed. how much is involved in doing this and is it possible to find a low mileage swap for cheap?
Old Oct 29, 2006 | 07:34 AM
AJxr's Avatar
y8 sohc vtec = cake, throw it in use your stock harness, get a p2p and wire vtec, call it a day
Old Oct 29, 2006 | 07:39 AM
John M's Avatar
Default Re: (AJxr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AJxr &raquo;</TD></TR><TR><TD CLASS="quote">y8 sohc vtec = cake, throw it in use your stock harness, get a p2p and wire vtec, call it a day</TD></TR></TABLE>
Old Oct 29, 2006 | 10:39 AM
arcboy's Avatar
New User
Default Re: (AJxr)
how do I do the p2p wire
Old Oct 29, 2006 | 11:15 AM
black2kcivic's Avatar
I think you have "rod knocking" vtec!
I had that problem in my car.
Old Oct 29, 2006 | 01:01 PM
AJxr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by arcboy &raquo;</TD></TR><TR><TD CLASS="quote">how do I do the p2p wire</TD></TR></TABLE> you buy a p2p (96-00 ex) ecu and plug it in, be sure to get a 5spd ecu if your car is 5spd or auto if your car is auto
Old Oct 29, 2006 | 01:04 PM
simplegreenmachine's Avatar
the tranny is fucked. same thing happened to me and a friend of mine, its funny stuff. does it make alot of noise when you let off the clutch and its in neutral?
Old Oct 29, 2006 | 02:07 PM
arcboy's Avatar
New User
Default Re: D16Y7 maybe ? (SpoolinFerio)
no, it doesn't do it in neutral or with the clutch in. it does do it under accerleration or deaccerleration. I do think that it is the tranny because now that I think of it it sounds like gear noise. but you would think that it would do it all the time.
Is the D16Y8 the only swap what about the D15B or ZC? I tried finding a Y8 but they are about impossible to find.
Can I use the Y7 accesories on the Y8 or do I have to have the Y8 stuff?
Old Oct 29, 2006 | 03:46 PM
Default Re: (OMG naD16 lol)
If you have an aftermarket intake, you will be able to hear V-Tec engagement on a single cam motor. You should not feel it though.
Old Oct 29, 2006 | 05:12 PM
quicksilver1689's Avatar
i ♥ snails
How can u hear vtec with an aftermarket intake on a motor that does not have a vtec head?
Old Oct 29, 2006 | 05:42 PM
UberMunkey's Avatar
don't forget to wire the knock sensor and do the iac plug if your reusing the stock harness.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by arcboy &raquo;</TD></TR><TR><TD CLASS="quote">no, it doesn't do it in neutral or with the clutch in. it does do it under accerleration or deaccerleration. I do think that it is the tranny because now that I think of it it sounds like gear noise. but you would think that it would do it all the time.
Can I use the Y7 accesories on the Y8 or do I have to have the Y8 stuff?</TD></TR></TABLE>
y8's are very common, try calling local junk yards. yes, pretty much everything is reusable from the y7 to the y8.
Old Oct 29, 2006 | 06:07 PM
vsmhatched's Avatar
Default Re: D16Y7 maybe ? (UberMunkey)
floorin it in y7 vtec land.....1/2 throttle till you get to 5 grand then floor it...sounds like mad tYte Hella 3rd geAr VteC y0
Old Oct 29, 2006 | 06:19 PM
TunerShark's Avatar
Default Re: D16Y7 maybe ? (GreyDel)
your head is in Vtec land but your car is still stuck in non-vtec Y7 land, sorry man. if you have exhaust or an intake, that extra little Kick or noise youre getting is probably a result from the intake or exhaust.
Old Oct 29, 2006 | 07:24 PM
Default Re: D16Y7 maybe ? (TunerShark)
most likely its the transmission. theres really no other reason it should do it lol
Old Oct 29, 2006 | 07:29 PM
Simon Tibbett's Avatar
Get a Y8 and sell me your Y7 lol
Old Oct 29, 2006 | 07:30 PM
k20EP3's Avatar
your car has over 200,000 miles you should check your valves. sometimes the valves tend to get looser as time goes on so id check the gap and your timeing.
Old Oct 29, 2006 | 08:23 PM
alacard's Avatar
by the way..if you are planning on swapping...i would really think about dohc....theres not too much sense in spending the money and time to swap a y8 in...just for a 20 or so hp gain.
