What axels in a b16 a rex
Old May 6, 2002 | 08:06 AM
puffinrice's Avatar
Default What axels in a b16 a rex
i went and got axels i could have sworn they were 90-93 integra axels with out ABS but when i got it home it was like 1/4 inch to long. im i supposed to use del sol axels or what? thanks guys
Old May 6, 2002 | 12:20 PM
EVOCELICA's Avatar
New User
Default Re: What axels in a b16 a rex (puffinrice)
teg axels should work just pop the ring like homie stated.
Old May 7, 2002 | 02:12 PM
Monty's Avatar
Default Re: What axels in a b16 a rex (EVOCELICA)
they will work if your using the 90-93 intermedieate shaft. If you have the SIR intermedieate shaft, then you will need to build some sir axles. Read the real info on axles on haspoorts site
http://www.hasport.com
hth,
Monty
http://www.norcalcrx.org
Old May 7, 2002 | 03:05 PM
rice_classic's Avatar
Default Re: What axels in a b16 a rex (Monty)
so if your swap comes with the intermediate shaft from and SIR and you get the Axles from an SIR then you don't have to build any..
Old May 8, 2002 | 07:09 PM
Bnjmn's Avatar
Make you own set of CRX SiR axles like they came with in Japan-
90-93 Integra Intermediate shaft
90-93 Integra Inner joints (correct one for each side)
86-89 Integra middle shafts and outer joints (they are the same on either side)
Perfect factory fit.
Every time.
Ben
philkehn
18
May 28, 2007 08:24 AM
.Grimace
Sep 29, 2005 08:28 AM
Phat_GSR
Jan 16, 2003 11:38 AM
ricodemus
Dec 4, 2002 06:28 AM
XANDER-666
Oct 7, 2002 12:04 PM
