best swap parts to use looking towards the future...
ok well i just picked up a 92 dx hatch shell, it has no mounts, no linkage, no ecu and no engine harness.(or drivetrain)
i have a turbo gsr project swap i am working on for the car, but in the mean time i picked up a 99 ex swap.
basically, i am wondering what would be the best parts to get now to make the ex work that i could reuse on the gsr swap at a later date.
what mounts?
what linkage?
what harness?
what ecu?
and if you could explain why thats the best idea that would be cool to.
i relise that some of these parts may not transfer, if you could point those out also that would be great
thanks a ton!
what mounts?
what linkage?
what harness?
what ecu?
thanks a ton!
i think you have to use 96-99 engine mounts and the linkage? pretty sure you need to use 94-00 integra mounts and linkage for the gsr later though.
run it as obd1 and use a p28, you can re chip this later to run the gsr.
i am not sure what your best option for the harness ...
halocore
16
Jul 31, 2008 09:50 PM
kpop
Jul 16, 2006 11:47 AM
