need help: '91 2.2L lunges after changing hoses
Old Oct 28, 2006 | 10:29 AM
jxl's Avatar
jxl
Default need help: '91 2.2L lunges after changing hoses
I just changed the bottom hose on my FITV and my heater hose after they ruptured. Now the car is stuttering and lunging when I give it gas in gear. Could this have something to do with the coolent, since I had almost all the hoses off of the T-stat?
thanks in advance -J
Modified by jxl at 2:55 PM 10/28/2006
Old Oct 28, 2006 | 03:46 PM
H2290's Avatar
Default Re: need help: '91 2.2L lunges after changing hoses (jxl)
Air in the coolant will do this. If you look where your thermostat is you will see a little vent valve on top of the housing. Let your car idle until the fan cuts on and then open that valve until a solid stream of coolant comes out.
Old Oct 29, 2006 | 08:40 AM
jxl's Avatar
jxl
Default Re: need help: '91 2.2L lunges after changing hoses (H2290)
thanks
I had a feeling it was that, I tried that but don't think I did it right the first time. I'll try again. thanks for the help!
-J
Modified by jxl at 1:53 PM 10/29/2006
Andrew Jensen
Dec 28, 2017 01:30 PM
BakoIntegradb1
Jan 21, 2013 01:39 PM
hondachris1994
Mar 21, 2006 11:13 PM
Snafubmx234
Mar 18, 2006 12:35 AM
tinkerbell
Jun 25, 2002 01:31 PM
