FS: 96-00 civic cluster replacement & it sweep like Defi
Where would I find this? Is this something that you made or is there a website I can see these at? Any other applications that these work in??
this sweet unit is made by evil auto, and im not if evil have a offical website but i saw they have a catalog at http://www.evilautostyle.com/
im not sure if they have other unit for different car but this unit is for 96-00 civic
bump
never seen anything like this... it looks awesome, but hows the install?
what exactly is being replaced?
the bezel? and
the needles? - did you just yank the needles off your stock ones and replace them?
- wondering because I've had people do that and the needles wont ever move again, regardless or alignment....I don't personally know so i cant say.. but I'd be very scared to
are there directions you can scan?
the bezel? and
its a direct replacement, u will need to use ur own cluster and open it, replace the 3 main section behind the cluster, which are the rpm, mph and water/gas, simple and easy coz is all a bolt on pieces. no need to pull out the needles, or break or damage anything.
I am interested and would like to see the back of the cluster?i also would like to know how the gauges work with the oem senders and do they just plug in to the oem harness and connectors?
