1995 USDM B18C1 - Semi-Built complete Longblock assembly w. extras!!
SOLD SOLD SOLD SOLD
1995 USDM B18C1 bottom end - SOLD
1998 USDM B18C1 cylinder head w/ obd-1 components - SOLD
Includes:
RS machining JDM ITR pistons .030mm over (coated)
P72 Rods
ACL race series bearings
Hastings piston rings
Block has been redecked, hot tanked, bored and honed by RS machining
Blox intake manifold
Stock throttle body
Stock injectors, fuel rail and FPR
Have all of the emissions parts for the GSR motor
Stock mounts
ACT 6 puck clutch unsprung w. heavy duty pressure plate
Spoon flywheel or stock flywheel
P72 transmission
ITR oil pump
ITR water pump
OEM oil cooler
OBD 1 wiring harness
All oil seals have been replaced - OEM only!
*Everything is built to manufacturer specs. to reduce friction that decreases the potential loss of horsepower in the motor's performance.
No miles are on this motor yet, and I am in the midst of finishing so its not done yet. Serious inquires only and make appointment with me so I can arrange a viewing or pickup of the motor please in advance.
Contact: 949-584-1236 name is Larry
HEAD IS SOLD, SHORTBLOCK, TRANSMISSION AND MANIFOLD ASSEMBLY REMAINING.
Before the machining:
And after machining:
Modified by SLVRSTN_DC4 at 7:36 PM 2/20/2007
Modified by SLVRSTN_DC4 at 10:42 AM 3/31/2007
Includes:
P72 Rods
Stock throttle body
Stock mounts
P72 transmission
ITR oil pump
ITR water pump
OEM oil cooler
good stuff, hopefully it will project about 180+ wheel horsepower! just throw cams in and you are all set to see 200+ whp
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SLVRSTN_DC4 »</TD></TR><TR><TD CLASS="quote">this will be one great motor </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by caLiH22A »</TD></TR><TR><TD CLASS="quote">BUMP! this is aLex!
nice, i wish i could buy...
this would be nice to try and bar my 95 ls with.
bump for you!
-Ray
bump for you!
-Ray
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiRay6 »</TD></TR><TR><TD CLASS="quote">nice, i wish i could buy...
bump for you!
-Ray</TD></TR></TABLE>
thanks a bunch bro, yeah i built this to make some decent power but i had nothing but plans to get this to pass smog, which i believe it will. comes with all the emissions stuff as well.
bump for you!
