Honda S2000 Honda S2000
k20 or 24 S2000 transplant
Old Oct 28, 2006 | 07:58 AM
orlandoRSXR's Avatar
Default k20 or 24 S2000 transplant
is this even possible or has anyone does this before? it would be nice to slap a hybrid engine k20/24 into the ap1.
Old Oct 28, 2006 | 09:08 AM
s2kdre's Avatar
Default Re: k20 or 24 S2000 transplant (orlandoRSXR)
k20 tranny bolts up to a f20c with an adapter plate, so im sure u could use a f20 trans on a k20. but the k20 spins a different way than others so im not sure.
Old Oct 28, 2006 | 10:07 AM
immortal's Avatar
Banned
that would be a downgrade.
Old Oct 28, 2006 | 12:31 PM
high_revs's Avatar
Default Re: k20 or 24 S2000 transplant (immortal)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by immortal &raquo;</TD></TR><TR><TD CLASS="quote">that would be a downgrade.</TD></TR></TABLE>
not to mention stupid... im sure if someone wanted to do it, it can easily happen.
Old Oct 28, 2006 | 02:01 PM
Miracle's Avatar
Default Re: k20 or 24 S2000 transplant (SB tuning)
Why would you want to is what I want to know?
Plus, you could not use the same transmission anyways... the K and F spin different directions, so you would have to do a full transplant... motor trans and all...
But before you decide to do that, give me your s2000 first, and let me drive it with the F....
Old Oct 28, 2006 | 02:05 PM
negcamber's Avatar
Default Re: k20 or 24 S2000 transplant (jdmhonda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmhonda &raquo;</TD></TR><TR><TD CLASS="quote">but the k20 spins a different way than others so im not sure.</TD></TR></TABLE>
Are you sure...I thought the K-series turned the "right" way.
K20 has more NA potential than the F20c for not much money. 230whp/160tq is not uncommon...but damn hard to get from an F20 or F22.
Old Oct 28, 2006 | 02:53 PM
ITRbroham's Avatar
shit post warrior
Default Re: k20 or 24 S2000 transplant (.Red.EM2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .Red.EM2 &raquo;</TD></TR><TR><TD CLASS="quote"> the K and F spin different directions </TD></TR></TABLE>
The K-series crankshaft rotates counter-clockwise like the F-series crankshaft.
Old Oct 28, 2006 | 03:55 PM
high_revs's Avatar
Default Re: k20 or 24 S2000 transplant (negcamber)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by negcamber &raquo;</TD></TR><TR><TD CLASS="quote">K20 has more NA potential than the F20c for not much money. 230whp/160tq is not uncommon...but damn hard to get from an F20 or F22.</TD></TR></TABLE>
you can easily achieve that from a f20c or f22c with bolts ons and a good tune...dont 4get the s2k has more of drivetrain loss
Old Oct 28, 2006 | 06:17 PM
negcamber's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SB tuning &raquo;</TD></TR><TR><TD CLASS="quote">
Hmmm...seems that 230 to the wheels is pretty hard to reach in an s2k. There is a huge thread on s2ki about how some folks are trying to do it...and it's tough. Definitely not able to reach that with just bolt ons...I've got quite a few bolt ons (toda header, T1R 63mm single, comptech CAI, Hondata IMG) and VAFC tuned by this forum's moderator and it's not even close to putting that to the wheels.
...dont 4get the s2k has more of drivetrain loss </TD></TR></TABLE>
I had not heard that before...seems that it is pretty close to the usual 15-20%. 240hp crank...most cars pull between 190-205 whp stock. What's the drivetrain loss on an RSX-S?
Old Oct 28, 2006 | 09:00 PM
327da9's Avatar
I remember reading how one of the biggest difficulties with a k20 is the mounting points on the block itself make it a pita even with custom mounts. The question is, does the head fit on the block
For everyone that thinks the k20 is a down grade, you couldnt be more wrong. Those engines are so potent in stock form, not to mention with i-vtec and vtc you get incredibly good torque bands for a n/a motor.
Old Oct 29, 2006 | 01:21 AM
RagingAngel's Avatar
Default Re: k20 or 24 S2000 transplant (327da9)
Quote, originally posted by JG-Fabrications »
K20A head flows 310-315 cfm on intake at .5" lift
F20c Head flows 320 cfm on intake at .5" lift
The only real difference in the K series and F series is the ivtec
Now for those looking for the best of both worlds (have i vtec in you st2k)
Head swap is being developed at our shop
The head is actually a bolt on, custom chain guides must be made, a few oil passages must be plugged and oil re routed (like ls vtec swaps), and custom chain covers must be made after that it is almost a 100% bolt up
We are in the slow progress of working out the bugs with this but we can assure it is fully possible to accomplish
-James
Old Oct 29, 2006 | 03:26 AM
high_revs's Avatar
Default Re: k20 or 24 S2000 transplant (RagingAngel)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RagingAngel &raquo;</TD></TR><TR><TD CLASS="quote">
-James </TD></TR></TABLE>
that should be intresting, how much is the kit gonna run?
Old Oct 29, 2006 | 03:35 AM
high_revs's Avatar
I had not heard that before...seems that it is pretty close to the usual 15-20%. 240hp crank...most cars pull between 190-205 whp stock. What's the drivetrain loss on an RSX-S?</TD></TR></TABLE>
k20z's put down around 170ish to the wheels bone stock, so drivetrain loss is pretty damn close compared to the s2000, and requires i/h/e + tune to reach 200whp, then from there your gonna need at the least a nice set of cams like some ips's still i give the k a lot of respect, gains most horsepower to mod out of any honda motor.... but i think the f20 or f22 is a better starting point...
Old Oct 29, 2006 | 05:04 AM
that should be intresting, how much is the kit gonna run?</TD></TR></TABLE>
I'm not the one developing the kit, you'll have to PM JG-Fabrications.
Old Oct 29, 2006 | 05:10 AM
high_revs's Avatar
thanx, just intrested to see how much it would be....there are adapter plates for everything
Old Oct 29, 2006 | 06:26 AM
Garrett's Avatar
Default Re: (SB tuning)
interesting tread
Old Oct 29, 2006 | 02:22 PM
Francesco's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by orlandoRSXR &raquo;</TD></TR><TR><TD CLASS="quote"> it would be nice to slap a hybrid engine k20/24 into the ap1. </TD></TR></TABLE>
no it wouldnt.
Old Oct 29, 2006 | 02:25 PM
ITRbroham's Avatar
shit post warrior
Default Re: k20 or 24 S2000 transplant (Francesco)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Francesco &raquo;</TD></TR><TR><TD CLASS="quote">
no it wouldnt.</TD></TR></TABLE>
x2
Old Oct 29, 2006 | 02:30 PM
Francesco's Avatar
Default Re: k20 or 24 S2000 transplant (ITRbroham)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITRbroham &raquo;</TD></TR><TR><TD CLASS="quote">
x2</TD></TR></TABLE>
Ill never understand why people want to put a FWD platform motor into a RWD platform car.
k20 motor is a good swap for integras and hatches, not the s2000 If you want to get creative, drop an s15 or 2jz in the s2000
Old Oct 29, 2006 | 02:36 PM
Garrett's Avatar
k20 motor is a good swap for integras and hatches, not the s2000 If you want to get creative, drop an s15 or 2jz in the s2000 </TD></TR></TABLE>
it's because the k20 head, give more power, everyone want to power
Old Oct 29, 2006 | 02:39 PM
high_revs's Avatar
Default Re: k20 or 24 S2000 transplant (Garrett)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Garrett &raquo;</TD></TR><TR><TD CLASS="quote">
it's because the k20 head, give more power, everyone want to power</TD></TR></TABLE>
for the price of the k20 head and the kit you can just get cams, valve train, and pistons for the f20c
Old Oct 29, 2006 | 02:42 PM
Garrett's Avatar
for the price of the k20 head and the kit you can just get cams, valve train, and pistons for the f20c</TD></TR></TABLE>
yeah but you still having no I-vtec
i-vtec give a wonderfull powerband
Old Oct 29, 2006 | 02:45 PM
high_revs's Avatar
i-vtec give a wonderfull powerband</TD></TR></TABLE>
so, you will be making more power which is why you said to slap on the k20 head in your previous post.
Old Oct 29, 2006 | 02:51 PM
Garrett's Avatar
so, you will be making more power which is why you said to slap on the k20 head in your previous post.</TD></TR></TABLE>
k20 head, pistons, cams,valves, .....
Old Oct 29, 2006 | 02:54 PM
high_revs's Avatar
f20c, high comp pistons, brian crower stage 3 cams
keep the k20 head on a k
