Where does this hoes go on a d16z6?
Old Oct 28, 2006 | 06:18 AM
Red_Si's Avatar
Default Where does this hoes go on a d16z6?
i need to know where this hoes goes to on a d16z6? I have it on the bottom of the tb right now and i don't think thats where it goes?
also where does the hose on the bottom of the tb go to??
Old Oct 28, 2006 | 07:04 AM
thesmogman's Avatar
Default Re: Where does this hoes go on a d16z6? (Red_Si)
That is where the coolant part attaches to #8
This is a better pic
Old Oct 28, 2006 | 07:15 AM
Timberland237's Avatar
Default Re: Where does this hoes go on a d16z6? (thesmogman)
Old Oct 28, 2006 | 08:01 AM
Red_Si's Avatar
Default Re: Where does this hoes go on a d16z6? (Timberland237)
ok and then it goes where? to the bottom of the tb?
Old Oct 28, 2006 | 08:24 AM
thesmogman's Avatar
On my A6 it goes to the tube under the TB then around to the IACV.
Old Oct 28, 2006 | 08:33 AM
black7hatch's Avatar
well does your engine overheat when the hose isnt hooked up?
tell me if im wrong, but cant you bypass the tb all together with the coolent hoses? i have a D16y7 and i just connected the hoses together instead of running them thru the tb.
Old Oct 28, 2006 | 09:49 AM
thesmogman's Avatar
Default Re: Where does this hoes go on a d16z6? (black7hatch)
Yes you can. But your TB can ice up in cold weather. No, it is not going to cause overheating. Not much coolant flows through it.
Old Oct 28, 2006 | 10:18 AM
suspendedHatch's Avatar
You can bypass it if you don't live in a freezing climate but you will also have to block off your FITV with a solid paper gasket or else you will get wildly fluctuating idle.
Old Oct 29, 2006 | 11:26 AM
Default Re: Where does this hoes go on a d16z6? (suspendedHatch)
sorry for jacking the thread. no i dont live in a freezing climate. i live in oregon. my friend and i did it and he said it wouldnt be a problem but i wanted to check and make sure. also my idle hasnt changed at all. what is a FITV?
Old Oct 29, 2006 | 11:41 AM
chitown_ef9si's Avatar
fitv is your fast idle thermo valve. not an expert but i believe what it does is when you first start your car it keep your idle up until your car warms up
giovi_ek
Oct 2, 2014 11:23 AM
bimonthly27
Jun 1, 2011 11:08 AM
INVALID
30
Sep 24, 2006 10:36 PM
n20sol
Jun 12, 2005 04:57 PM
wing
Jun 8, 2004 11:49 PM
