Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
When does V-TEC kick in?
Old Oct 27, 2006 | 10:43 PM
sce310's Avatar
From: South San Francisco, California, United States
Default When does V-TEC kick in?
hi, just a simple quick question, when does V-TEC kick in for the 06 Civic sedan EX? or pretty much for the R18A1?
Old Oct 28, 2006 | 12:25 AM
K20Death's Avatar
When god comes down and deems thine vehicale worthy for such a just and worthy cause... only then can your car be capable of becoming something more. Something only the gods deem necessary, the almighty VTEC!1one!
Old Oct 28, 2006 | 02:46 AM
Demonis's Avatar
*sigh* I really dont know, but i would assume 4800~5200 or somewhere close to that... Whats the redline on an R18 anyways? 7200?
Old Oct 28, 2006 | 06:49 AM
0oE's Avatar
0oE
Default Re: (Demonis)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by K20Death &raquo;</TD></TR><TR><TD CLASS="quote">When god comes down and deems thine vehicale worthy for such a just and worthy cause... only then can your car be capable of becoming something more. Something only the gods deem necessary, the almighty VTEC!1one!</TD></TR></TABLE>
LOL !!!!
Old Oct 28, 2006 | 07:28 AM
TRE_'s Avatar
Default Re: (K20Death)
hardy har har har stupidest **** i've read in a while
To the OP:
Graph is specfic for R18
Some interesting info on the new SOHC honda motors:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">Other technologies include a variable-length intake manifold using longer manifolds at low RPMs and shorter manifolds at high RPMs for an optimum ram effect and piston oil jets which cool down pistons to avoid engine knocking. As a result of these technologies and a compression ratio of 10.5:1, this 1.8 liter SOHC i-VTEC engine makes 140hp at 6300rpm and 174Nm of torque at 4300rpm.
Old Oct 28, 2006 | 06:12 PM
K20Death's Avatar
Default Re: (TRE_)
When I see that question asked that many times thats the first thing that came to mind besides the actual fact of how it operates.
Old Oct 29, 2006 | 02:38 PM
TRAG's Avatar
Old Oct 29, 2006 | 03:10 PM
japspecjohn's Avatar
Default Re: When does V-TEC kick in? (sce310)
idk listen for it to "crack" lol
Old Oct 29, 2006 | 03:19 PM
eL's Avatar
eL
The iVTEC in the R18 doesn't "kick" in. Do some research
Old Oct 29, 2006 | 03:24 PM
LxXsilenceXxP's Avatar
Default Re: (eL)
vtec kicks in when chuck norris says vtec can kick in.
Old Oct 29, 2006 | 03:32 PM
Declectic's Avatar
the R18 has vtec?
Old Oct 29, 2006 | 04:08 PM
Nighthawk R18's Avatar
Default Re: (SeanJohn1802)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SeanJohn1802 &raquo;</TD></TR><TR><TD CLASS="quote">the R18 has vtec?</TD></TR></TABLE>
it has iVTEC
unless your asking someone who said it had "VTEC" instead of "iVTEC",
thennn yeaaa
Old Oct 29, 2006 | 07:26 PM
refuge.'s Avatar
can you guys even feel the v-tech come on?
Old Oct 29, 2006 | 07:58 PM
sce310's Avatar
Default Re: (0oE)
redline is 6800...I was guessin as well that vtec kicks in around 5k or up
Modified by sce310 at 12:07 AM 10/30/2006
Old Oct 29, 2006 | 08:03 PM
TRAG's Avatar
O. I didnt know that this was a thread for the R18..i thought it was for the K20Z3. My bad. dis reguard that 5900 post,i have no clue
Old Oct 30, 2006 | 11:16 AM
modifyORdie's Avatar
Default Re: When does V-TEC kick in? (refuge.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by refuge. &raquo;</TD></TR><TR><TD CLASS="quote">can you guys even feel the v-tech come on?</TD></TR></TABLE>
vtech comes on when you push the talk button....
however if you mean iVTEC or the older version VTEC...in a sohc engine ...no you cannot
Old Oct 30, 2006 | 11:33 AM
liketofry's Avatar
Running bone-stock, no not really. But on the freeway at 5th gear you can feel a little "push" when you pass 3,500.
Old Oct 30, 2006 | 11:49 AM
Default Re: When does V-TEC kick in? (liketofry)
there is no H in VTEC
there is no dash (-) either
and the R18 has iVTEC
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by liketofry &raquo;</TD></TR><TR><TD CLASS="quote">Running bone-stock, no not really. But on the freeway at 5th gear you can feel a little "push" when you pass 3,500. </TD></TR></TABLE>
3,500 sounds about right
Old Oct 30, 2006 | 01:02 PM
Default Re: When does V-TEC kick in? (Nighthawk R18)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nighthawk R18 &raquo;</TD></TR><TR><TD CLASS="quote">
3,500 sounds about right</TD></TR></TABLE>
its more along the 5k range...i know for the k20 its about 5800
Old Oct 30, 2006 | 04:52 PM
Default Re: When does V-TEC kick in? (modifyORdie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by modifyORdie &raquo;</TD></TR><TR><TD CLASS="quote">
its more along the 5k range...i know for the k20 its about 5800</TD></TR></TABLE>
oh, i thought it started way early since its ivtec
for you
Old Oct 30, 2006 | 06:19 PM
eL's Avatar
eL
Default Re: (sce310)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sce310 &raquo;</TD></TR><TR><TD CLASS="quote">redline is 6800...I was guessin as well that vtec kicks in around 5k or up
Modified by sce310 at 12:07 AM 10/30/2006</TD></TR></TABLE>
The R18 switches to the "high output" cam at 3500 didnt you see the damn chart above?
People are so misinformed on this site it's a shame.
Old Oct 30, 2006 | 06:39 PM
Default Re: (eL)
then i was fawking right.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by modifyORdie &raquo;</TD></TR><TR><TD CLASS="quote">
give me back my
Old Oct 30, 2006 | 10:16 PM
Beefkake's Avatar
Sometimes I hate people.
Modified by Beefkake at 11:35 PM 10/31/2006
Old Oct 30, 2006 | 10:28 PM
Declectic's Avatar
Default Re: When does V-TEC kick in? (Beefkake)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Beefkake &raquo;</TD></TR><TR><TD CLASS="quote">
Actually, there is a dash (-) in i-vtec. It's on the engine and on the sides of the si. I know we're talking about an r18 but it's still spelled i-vtec.</TD></TR></TABLE>
your joking right? your proving NO ONE WRONG OR RIGHT ... it wasn't about the "i"-vtec...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nighthawk R18 &raquo;</TD></TR><TR><TD CLASS="quote">there is no dash (-) either
Old Oct 31, 2006 | 04:12 AM
WILD_WILL's Avatar
I always use the term when VTEC cracks yea i have an 06 SI with I-VTEC it from what it says its running in the lower rpm range unlike previous versions of it. I def feel VTEC when it cracks open just punch the throttle and enjoy.
P.S. When people ask when does VTEC crack they mean when does it get real loud and your passenger cream's him or her self as you rev to the moon !
