What axels/hubs/knuckles to use for SI motor in HF?
Old Oct 27, 2006 | 01:00 PM
spunautosports's Avatar
Default What axels/hubs/knuckles to use for SI motor in HF?
I think the stock ones on the HF are smaller and will not fit the SI axels am I correct? Should I change over to the SI set up? If so I have hubs and knuckles from a DA will this work or only with B-Series?
Old Oct 27, 2006 | 01:04 PM
cr-x-91's Avatar
u need si or dx hubs and axels if ur using the si tranny. and if u use that tranny u can use the teg ones but would recomend using ef spindles.
Old Oct 27, 2006 | 01:41 PM
Targa250R's Avatar
be professional
Default Re: (cr-x-91)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spunautosports &raquo;</TD></TR><TR><TD CLASS="quote">I think the stock ones on the HF are smaller and will not fit the SI axels am I correct?</TD></TR></TABLE>
That is correct, the Si axles will not fit the HF hubs. However, the HF axles will fit the Si transmission, so if you have HF axles then you can reuse them.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cr-x-91 &raquo;</TD></TR><TR><TD CLASS="quote">u need si or dx hubs and axels if ur using the si tranny.</TD></TR></TABLE>
No, that is incorrect. He can use HF axles with the Si transmission.
Old Oct 27, 2006 | 01:47 PM
SupraRXZ's Avatar
you can use DA brakes if you want on a Si tranny, you can use DA brakes with HF tranny if you wanted but you just have to change the axles.
Im getting DA brakes this weekend putting them with si axles and a hf tranny. just doing this for now while im building my d15b
also you gotta either get a prelude or EX sedan 15/16 MC or DA 15/16 MC and a 260v brake booster
Old Oct 27, 2006 | 02:23 PM
junior40er's Avatar
Default Re: (Targa250R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R &raquo;</TD></TR><TR><TD CLASS="quote">
No, that is incorrect. He can use HF axles with the Si transmission.</TD></TR></TABLE>
nailed it right there
Old Oct 27, 2006 | 02:49 PM
Default Re: (junior40er)
How much WHP and TQ can the HF axels take? If they can take avbout 150 with a lsd then Ill just keep them.
Old Oct 27, 2006 | 03:26 PM
dr_latino999's Avatar
Default Re: (spunautosports)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spunautosports &raquo;</TD></TR><TR><TD CLASS="quote">How much WHP and TQ can the HF axels take? If they can take avbout 150 with a lsd then Ill just keep them.</TD></TR></TABLE>Well I don't think anyone has ever pushed them too far since most people swap out the knuckles. Now on a matter of safety, if you are increasing power exponentially such as the HF chassis, increase the brakes as well. Also, axles can take as much power as you throw at them until one of two things happen - fatigue in the metal just causes the axle to break, or you start trying to be a stunner and doing burnouts and the such.
Old Oct 27, 2006 | 05:18 PM
shatterd lens01's Avatar
Default Re: What axels/hubs/knuckles to use for SI motor in HF? (spunautosports)
ive read an good oem up grade would be to use an 4-door ex set up...my souce is car-tech honda book can be found at barnes and nobels for 20 buucks.
Old Oct 27, 2006 | 05:56 PM
Default Re: What axels/hubs/knuckles to use for SI motor in HF? (shatterd lens01)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shatterd lens01 &raquo;</TD></TR><TR><TD CLASS="quote">ive read an good oem up grade would be to use an 4-door ex set up...my souce is car-tech honda book can be found at barnes and nobels for 20 buucks.</TD></TR></TABLE>Or you could just use the free Search button in the corner. And those EX setups are Rare, took me three years to find a set in good condition.
Old Oct 28, 2006 | 08:26 AM
Default Re: What axels/hubs/knuckles to use for SI motor in HF? (dr_latino999)
Bump!
Old Oct 28, 2006 | 10:08 AM
ryan89crx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spunautosports &raquo;</TD></TR><TR><TD CLASS="quote">Bump!</TD></TR></TABLE>bump for what? your question was already answered...
HFpower
Jan 10, 2007 11:41 AM
e jay one
May 26, 2006 01:34 PM
donaldmejr
Dec 13, 2005 05:48 PM
pdiddyparsons
Feb 20, 2003 01:04 PM
pdiddyparsons
Feb 18, 2003 11:34 AM
