4-wire o2 sensor clearence (srched!!)
Old Oct 27, 2006 | 11:09 AM
Coltmorris's Avatar
Default 4-wire o2 sensor clearence (srched!!)
Well Yea, Im the one with alll the damn o2 sensor problems (poor rich-running motor). Well I actually got her up on a lift today and took a look at my o2 sensor which is in the bung in the midpipe--right before the cat. WELL, the top of the sensor is scraping up against my intermidiate shaft boot. And, the rotation/heat scraped allll the way through the sensors sheilding and now its a pile of ****. Anyone else have this problem? its a D16A in a 91 dx, should I try and move the bung? or get a new sensor or what?? Thanks
Old Oct 27, 2006 | 11:35 AM
Tippyman's Avatar
Default Re: 4-wire o2 sensor clearence (Coltmorris)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Coltmorris &raquo;</TD></TR><TR><TD CLASS="quote">Well Yea, Im the one with alll the damn o2 sensor problems (poor rich-running motor). Well I actually got her up on a lift today and took a look at my o2 sensor which is in the bung in the midpipe--right before the cat. WELL, the top of the sensor is scraping up against my intermidiate shaft boot. And, the rotation/heat scraped allll the way through the sensors sheilding and now its a pile of ****. Anyone else have this problem? its a D16A in a 91 dx, should I try and move the bung? or get a new sensor or what?? Thanks </TD></TR></TABLE>
You may want to move the 02 sensor further up the header. Right on one of the runners, like this:
It has a bung right before the cat, and one on a runner. I used the one on the runner, just like stock.
Old Oct 27, 2006 | 11:37 AM
Coltmorris's Avatar
Default Re: 4-wire o2 sensor clearence (Tippyman)
oooo--ok yea..i didnt consider that. Cool, I will give it a shot!
Old Oct 27, 2006 | 12:10 PM
3s0n3's Avatar
had and fixed that prob ... plug the hole and drill out anotherone in a place where its good for you... drill a hole and weld in a nut with the correct thread for the sensor. took me a half hour and has worked fine since
Old Oct 27, 2006 | 12:12 PM
Tippyman's Avatar
Default Re: (3s0n3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 3s0n3 &raquo;</TD></TR><TR><TD CLASS="quote">had and fixed that prob ... plug the hole and drill out anotherone in a place where its good for you... drill a hole and weld in a nut with the correct thread for the sensor. took me a half hour and has worked fine since</TD></TR></TABLE>
Old Oct 27, 2006 | 01:29 PM
Coltmorris's Avatar
Default Re: (Tippyman)
yea..I was assuming that would be the solution--but hoping there was an easier fix--haha--thanks a lot guys!
LostAndFound
18
Jun 25, 2004 10:46 PM
JoshRambo
May 15, 2003 01:09 PM
ldodol
Mar 29, 2003 01:24 PM
