Pop sound
Old May 6, 2002 | 05:32 AM
fred92htch's Avatar
Default Pop sound
I have a 92 dx hatch and have had a b18c in it for a few days. I,ve put about 300 miles on it so far. Twice, at different times when I let off the gas I heard a kind of pop. It sounds almost like a cv joint when they are going out but this has only happened the two times. Another time was when I accelerated and let off then accelerated again. If I try to make the sound happen I can't. Is this something Accura drivetrains do? I jacked up the car today and spun the wheels by hand back and forth and there is nothing abnormal looking or sounding. Any ideas? Thanks.
_______
Old May 6, 2002 | 07:30 AM
DragII's Avatar
25 Year Member
Default Re: Pop sound (fred97gle)
where is the noise coming from? do you have you exhaust hooked up?
Old May 6, 2002 | 09:04 AM
DR. ON POINT's Avatar
Banned
Default Re: Pop sound (SuperDragII)
sounds like u are backfiring to me, what kinda exhaust do u have on the car
Old May 6, 2002 | 09:37 AM
markpaco's Avatar
I have the same problem. Sorry I can't help you out but I think it is something in the front suspension or engine mounts. You might want to check that they are tightened well. I've checked mine and haven't found anything.
Old May 6, 2002 | 10:14 AM
rodrez.'s Avatar
Default Re: Pop sound (On Point EK)
Yeah, it could be a loose, or worn mount, and you might be hearing the motor shift backward under load, or maybe even the header tapping the block, if it's stressed by a shortened, or solid mounted exhaust. good luck
Old May 6, 2002 | 10:43 AM
fred92htch's Avatar
Default Re: Pop sound (rodrez)
I have a DC 4-1 header into a test pipe into the stock exhaust for now. It sounds like it's coming from under the front of the car. Definatey not a backfire.
[Modified by fred97gle, 7:44 PM 5/6/2002]
Old May 13, 2002 | 05:41 AM
fred92htch's Avatar
It's a CV joint. I jacked up the car and looked around and saw some grease inside my left front rim. Cleaned everything up and saw a small, quarter inch split in my CV boot. I shot some more grease in there and rigged up a temporary patch till I can replace it. The noise quit with the new grease.
accord95vtec
Sep 10, 2009 02:51 PM
lambofgoddess
Honda Civic (2001 - 2005)
Aug 1, 2007 01:51 PM
haroldthefly91crx
22
Jun 12, 2007 06:28 AM
s2k_al
Honda S2000
Aug 26, 2004 05:22 PM
