Suspension & Brakes Theory, alignment, spring rates....
Koni shocks still good?
Old Oct 27, 2006 | 10:10 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Koni shocks still good?
Back in January 2002 I installed brand new OTS Koni Sport shocks, with about 105,000 miles on my car. Now my car has 238,000 on it, and the shocks have been through H&R Sport springs, Koni GC's with 380/450 rates, and now for a little over a year they have stock springs in front and ITR springs out back, all shocks set to the lowest perch.
I'm just wondering if it's possible that the shocks could still be good with that many miles on them. It's been pretty much just daily driving for the past 135K miles. What does a worn-out Koni shock feel like when you adjust it from full soft to full stiff? If I set mine to full stiff, it still feels pretty darn stiff even with factory springs. If I set it on full soft and push down on the rear of the car, it comes right back up with maybe just the tiniest bit of residual motion, almost none at all really.
The problem is that I've had them for so long now, I don't remember what they were like when they were brand new, or if it's really that much different from how it feels now. I do know that even with the stock springs (ITR stock in back) at full soft, the ride feels decent, and at full stiff I can feel every little bump in the road.
Thoughts?
Old Oct 27, 2006 | 04:51 PM
dvp's Avatar
dvp
Default Re: Koni shocks still good? (PatrickGSR94)
Well, they're definately not blown. If you have never autocrosses or tracked with them it's very possible they are just fine. Maybe a little worn but still operational.
Old Oct 28, 2006 | 06:14 AM
slkleltlclh's Avatar
Default Re: Koni shocks still good? (dvp)
put some load on them without the springs, and if the strut comes back all the way on its own, ur good
Old Oct 28, 2006 | 11:35 PM
chrisw85's Avatar
Default Re: Koni shocks still good? (slkleltlclh)
not necessarily. the shock shaft popping out on its own really fast can be an indicator that the rebound valving is shot. The stiffer you set the shocks the harder it should be to pull on the piston. the compression and rebound stroke should be controlled and smooth.
Black R
Jul 27, 2009 12:10 PM
TonyRomo
Suspension & Brakes
Apr 10, 2009 10:38 PM
Partizan
Suspension & Brakes
Jun 15, 2007 09:39 PM
J-HAWK
Feb 25, 2006 06:22 PM
SouLaQuaRiuS
Nov 4, 2003 02:20 PM
