Suspension & Brakes Theory, alignment, spring rates....
ASR Brace
Old Oct 27, 2006 | 10:02 AM
Djole_V's Avatar
Default ASR Brace
What sway bars work with an EK Civic i was thinking of buying eibach the anti roll kit will it work with it or all of the sway bars work with it?
Old Oct 27, 2006 | 10:37 AM
JunY's Avatar
Default Re: ASR Brace (Djole_V)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Djole_V &raquo;</TD></TR><TR><TD CLASS="quote">What sway bars work with an EK Civic i was thinking of buying eibach the anti roll kit will it work with it or all of the sway bars work with it?</TD></TR></TABLE>
The Eibach rear swaybar is not compatable with the ASR brace on the EK. There's a extra bend in the Swaybar which makes it wider apart to mount.
If you search around there have been few people that have successfully installed other brand name swaybars onto the ASR brace.
Old Oct 27, 2006 | 10:49 AM
Djole_V's Avatar
Default Re: ASR Brace (JunY)
what about suspension techniques?
Old Oct 27, 2006 | 11:28 AM
nonsense's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Djole_V &raquo;</TD></TR><TR><TD CLASS="quote">what about suspension techniques?</TD></TR></TABLE>
what's wrong with running an ITR bar? It might be less money than the aftermarket bars
Old Oct 27, 2006 | 06:10 PM
JunY's Avatar
Default Re: ASR Brace (nonsense)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nonsense &raquo;</TD></TR><TR><TD CLASS="quote">
what's wrong with running an ITR bar? It might be less money than the aftermarket bars </TD></TR></TABLE>
He probably doesn't have a front sway. That's my guess.
Old Oct 27, 2006 | 06:38 PM
Heretic:Si's Avatar
i've wondered this also. thinking about the 18mm cusco or 21mm blox, searched around and i've never found anything about these two.
Old Oct 28, 2006 | 07:46 AM
Djole_V's Avatar
Default Re: ASR Brace (Heretic:Si)
no i dont have a front one too so im thinking of buying both of them at once so if I put the asr brace most of the can fit. The thing is is that i have no idea.
Old Oct 30, 2006 | 06:58 AM
nonsense's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JunY &raquo;</TD></TR><TR><TD CLASS="quote">He probably doesn't have a front sway. That's my guess.</TD></TR></TABLE>
neither do I, and I have the ITR rear bar.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Djole_V &raquo;</TD></TR><TR><TD CLASS="quote">no i dont have a front one too so im thinking of buying both of them at once so if I put the asr brace most of the can fit. The thing is is that i have no idea.</TD></TR></TABLE>
If you really want a front and rear sway bar, and you want the ASR brace too, you should get the rear ITR sway bar and then pick a front sway to go with it.
Your options for front bars are Civic EX, Civic Si, and aftermarket. If you get an aftermarket there are some manufacturers that have setups for cars without a factory front sway bar. If you go with the EX or Si front bars you will need the corresponding front lower control arms for the bar you choose.
Here's what you would be looking for if you wanted an aftermarket front bar on your civic:
http://cgi.ebay.com/ST-FRONT-A...wItem
siblues
Suspension & Brakes
Mar 19, 2008 03:17 PM
Rob.
22
Feb 5, 2007 09:13 AM
MugenManR
Jan 14, 2007 07:34 AM
young noob
Suspension & Brakes
Sep 12, 2006 11:29 PM
cre18
17
Mar 22, 2002 07:23 PM
