Motors running really lean... new cam = bigger injecters?
Old Oct 27, 2006 | 07:51 AM
Marcpb443's Avatar
Default Motors running really lean... new cam = bigger injecters?
Well i blew my motor, and i pulled the spark plugs and its running extremly lean, I was wondering if I needed bigger injecters? im running stock ones right now.
I have an aftermarket cam, a gude cam. i plan on rebuilding it so I want to know if i should put bigger injecters in there or not. I have spare ones sitting around but they are froman h22a.
thanks
Old Oct 27, 2006 | 07:58 AM
ej1 assasin's Avatar
Default Re: Motors running really lean... new cam = bigger injecters? (Marcpb443)
what kinda motor is it?
Old Oct 27, 2006 | 08:12 AM
-Gary-'s Avatar
How did you blow it? Burnt a hole through the piston? You would have o be running VERY lean to have issues due to a cam swap.
Old Oct 27, 2006 | 08:53 AM
Marcpb443's Avatar
Default Re: (-Gary-)
Spun a bearing, diffrent story on how i blew it
Forgot to add its a d16z6. i didnt blow it because its running to lean.
Old Oct 27, 2006 | 09:01 AM
spoonracer84eg's Avatar
Default Re: (Marcpb443)
You could always upgrade injectors but it does not look like you have enough upgrades to have to get them. You have another issue I believe.
Old Oct 27, 2006 | 10:12 AM
Marcpb443's Avatar
Default Re: (spoonracer84eg)
hrm... would I need a tune, maybe?
tchickenBAKAWK
Jun 15, 2011 09:29 AM
allmotorlsbaby
Feb 3, 2009 03:33 AM
darkblue1998ls
Nov 28, 2005 01:34 PM
96-EJ6 B18C
Jan 12, 2004 09:39 AM
