SoCal: FS/Trade: LS B18A/B Intake Manifold Gasket Hondata/NextGear Thermoshield Technology
I have a Next Gear Thermal Technology Intake Manifold Gasket I got off of EBAY for $57 Bux awhile ago... I have no use for it now that I'm running a B16A Motor. I will let it go for 40.00 Picked up or Shipped in our around Cali, Los Angeles Prefered. It's for a B18AB. I will trade for some mad JDM parts yo, or a IM Gasket for a B16A Vtec. Thanks for reading and let's see what happens....
Jo
email me @:
East_los_angeles_fresh@yahoo.com
Description:
Before air can enter the combustion chamber of your engine, it first has to enter the air filter, travel through intake piping or tubing, pass through the throttle body, enter the intake manifold, and finally enter the cylinder head. There are many points along the path of this air flow where the air encounters a heat source. The ambient air temperature within the engine compartment can heat all of the surfaces along this path. This is called heat soak and it robs power from your engine. Most of the power robbing heat soak occurs when the cylinder head heats up the intake manifold.
Nextgear Intake Manifold Gaskets prevent this heat soak from occurring by insulating the intake against the unwanted heat generated by the cylinder head. NextGear Thermoshield Gaskets are direct replacement parts for your OEM intake manifold gasket. Thermoshield Gaskets increase the power output from your engine by preventing heat soak between the cylinder head and the intake manifold keeping your intake cooler. A cooler intake means denser more oxygen rich air and a better fuel burn resulting in more power.
How do Thermoshield Gaskets work? They maintain a colder air charge all the way to the combustion chamber. Cold air is denser than hot air but has less volume. When cold air is delivered to the combustion chamber, the fuel/air mixture within the chamber contains more oxygen, which means a better burn, and more power.
If you've spent time and money installing a cold air system then you know the value of cold air in the combustion chamber. But if you're not careful, just when the air is hitting the most critical part of the system, unwanted heat soak can undo all the effort you spent getting the air cold. NextGear Thermoshield Gaskets as provide a line of defense against heat soak, and a strong offense for making horsepower.
Features:
* Reduce air inlet temperatures for up to 5% HP Gain
* Made of high temp resistant hard plastic, extremely durable, will not deteriorate
* Unlike OEM intake gaskets, this can be used over and over again
* Worthwhile addition when upgrading to a cold air intake, or upgraded intake manifold
Application:
* 90-01 Acura Integra LS, RS, GS - 1.8L DOHC Non VTEC B18A, B18B
Condition:
* New in original packaging. Never used
Jo
email me @:
Description:
Features:
Application:
Condition:
turnsignalandy
10
Oct 30, 2006 04:51 PM
